pqShowWidgetDecorator.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqShowWidgetDecorator_h
33 #define pqShowWidgetDecorator_h
35 #include "pqApplicationComponentsModule.h"
37 #include "vtkWeakPointer.h"
38
43 class PQAPPLICATIONCOMPONENTS_EXPORT pqShowWidgetDecorator : public pqBoolPropertyWidgetDecorator
44 {
45  Q_OBJECT
47
48 public:
50
51  bool canShowWidget(bool show_advanced) const override
52  {
53  (void)show_advanced;
54  return this->isBoolProperty();
55  }
56
57 private:
58  Q_DISABLE_COPY(pqShowWidgetDecorator)
59 };
60
61 #endif
pqBoolPropertyWidgetDecorator is a base class for enable/disable or show/hide widgets based on the st...
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
Override this method to override the visibility of the widget in the panel.
pqShowWidgetDecorator can be used to show/hide a widget based on the status of another property not d...
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
