pqBoolPropertyWidgetDecorator.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqBoolPropertyWidgetDecorator_h
33 #define pqBoolPropertyWidgetDecorator_h
35 #include "pqApplicationComponentsModule.h"
37 #include "vtkWeakPointer.h"
38
44 class PQAPPLICATIONCOMPONENTS_EXPORT pqBoolPropertyWidgetDecorator
46 {
47  Q_OBJECT
49
50 public:
53
54  bool isBoolProperty() const { return this->BoolProperty; }
55
56 Q_SIGNALS:
57  void boolPropertyChanged();
58
59 protected:
61  QString Function;
62  int Index;
63  unsigned long ObserverId;
65  QString Value;
66
67 private:
68  Q_DISABLE_COPY(pqBoolPropertyWidgetDecorator)
69
70
73  void updateBoolPropertyState();
77  void setBoolProperty(bool val);
78 };
79
80 #endif
pqBoolPropertyWidgetDecorator is a base class for enable/disable or show/hide widgets based on the st...
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
vtkWeakPointer< vtkSMProperty > Property
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
