pqPropertyWidgetDecorator.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqPropertyWidgetDecorator_h
33 #define pqPropertyWidgetDecorator_h
35 #include "pqPropertyWidget.h"
36 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
37
38 class vtkPVXMLElement;
47 class PQCOMPONENTS_EXPORT pqPropertyWidgetDecorator : public QObject
48 {
49  Q_OBJECT
50  typedef QObject Superclass;
51
52 public:
62  ~pqPropertyWidgetDecorator() override;
63
67  pqPropertyWidget* parentWidget() const;
68
77  virtual bool canShowWidget(bool show_advanced) const
78  {
79  Q_UNUSED(show_advanced);
80  return true;
81  }
82
91  virtual bool enableWidget() const { return true; }
92
97  static pqPropertyWidgetDecorator* create(vtkPVXMLElement* xml, pqPropertyWidget* parent);
98
99 Q_SIGNALS:
105  void visibilityChanged();
106  void enableStateChanged();
107
108 protected:
109  vtkPVXMLElement* xml() const;
110
111 private:
112  Q_DISABLE_COPY(pqPropertyWidgetDecorator)
113
115 };
116
117 #endif
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
Override this method to override the enable state of the widget in the panel.
Override this method to override the visibility of the widget in the panel.
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
