pqPVApplicationCore.h
3  Program: ParaView
4  Module: pqPVApplicationCore.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqPVApplicationCore_h
33 #define pqPVApplicationCore_h
35 #include "pqApplicationCore.h"
36
37 #include "pqApplicationComponentsModule.h" // for exports
38 #include <QList>
39 #include <QPointer>
40
41 class pqAnimationManager;
42 class pqPythonManager;
43 class pqSelectionManager;
44 class pqTestUtility;
45 class QMenu;
46 class QWidget;
47
53 class PQAPPLICATIONCOMPONENTS_EXPORT pqPVApplicationCore : public pqApplicationCore
54 {
55  Q_OBJECT
57
58 public:
59  pqPVApplicationCore(int& argc, char** argv, pqOptions* options = 0);
60  ~pqPVApplicationCore() override;
61
67  {
68  return qobject_cast<pqPVApplicationCore*>(Superclass::instance());
69  }
70
76  pqSelectionManager* selectionManager() const;
77
81  // animation subsystem -- saving movies, creating scenes etc.
82  pqAnimationManager* animationManager() const;
83
87  pqTestUtility* testUtility() override;
88
93  pqPythonManager* pythonManager() const;
94
101  virtual void registerForQuicklaunch(QWidget*);
102
103  void loadStateFromPythonFile(const QString& filename, pqServer* server);
104
105 public Q_SLOTS:
109  void quickLaunch();
114  void startSearch();
115
116 Q_SIGNALS:
122  void aboutToShowQuickLaunch();
123
124 protected:
128  bool eventFilter(QObject* obj, QEvent* event) override;
129
130  QPointer<pqSelectionManager> SelectionManager;
131  QPointer<pqAnimationManager> AnimationManager;
132
134  QList<QPointer<QWidget> > QuickLaunchMenus;
135
136 private:
137  Q_DISABLE_COPY(pqPVApplicationCore)
138 };
139
140 #endif
static pqPVApplicationCore * instance()
Returns the pqPVApplicationCore instance.
This class is the crux of the ParaView application.
QPointer< pqAnimationManager > AnimationManager
pqAnimationManager manages the Animation sub-system.
pqSelectionManager is the nexus for introspective surface selection in paraview.
pqPythonManager is a class to facilitate the use of a python interpreter by various paraview GUI comp...
QList< QPointer< QWidget > > QuickLaunchMenus
QPointer< pqSelectionManager > SelectionManager
pqPythonManager * PythonManager
pqPVApplicationCore is the application code used by ParaView-based applications that use more of Para...
Command line options for pqClient.
Definition: pqOptions.h:45
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
virtual pqTestUtility * testUtility()
Provides access to the test utility.
