pqPVApplicationCore is the application code used by ParaView-based applications that use more of ParaView's functionality than that provided by pqApplicationCore such as the the selection manager, animation manager etc. More...
#include <pqPVApplicationCore.h>
Public Slots | |
| void | quickLaunch () |
| Pops-up the quick launch dialog. More... | |
| void | startSearch () |
| Pops-up the search dialog if the focused widget is QAsbstractItemView type. More... | |
Public Slots inherited from pqApplicationCore | |
| void | prepareForQuit () |
| Applications calls this to ensure that any cleanup is performed correctly. More... | |
| void | quit () |
| Calls QCoreApplication::quit(). More... | |
| void | loadConfiguration (const QString &filename) |
| Load configuration xml. More... | |
| void | loadConfigurationXML (const char *xmldata) |
| void | render () |
| Renders all windows. More... | |
Signals | |
| void | aboutToShowQuickLaunch () |
| Emitted whenever the quickLaunch dialog is about to show. More... | |
Signals inherited from pqApplicationCore | |
| void | aboutToLoadState (vtkPVXMLElement *root) |
| Fired before a state xml is being loaded. More... | |
| void | stateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator) |
| Fired when a state file is loaded successfully. More... | |
| void | stateSaved (vtkPVXMLElement *root) |
| Fired to save state xml. More... | |
| void | undoStackChanged (pqUndoStack *) |
| Fired when the undo stack is set. More... | |
| void | loadXML (vtkPVXMLElement *) |
| Fired on loadConfiguration(). More... | |
| void | forceFilterMenuRefresh () |
| Fired when the filter menu state needs to be manually updated. More... | |
| void | updateMasterEnableState (bool) |
| Fired when master changed. More... | |
| void | clientEnvironmentDone () |
| Fired when the ParaView Client infrastructure has completed setting up the environment. More... | |
| pqPVApplicationCore (int &argc, char **argv, pqOptions *options=0) | |
| ~pqPVApplicationCore () override | |
| pqSelectionManager * | selectionManager () const |
| Provides access to the selection manager. More... | |
| pqAnimationManager * | animationManager () const |
| Provides access to the animation manager. More... | |
| pqTestUtility * | testUtility () override |
| Provides access to the test utility. More... | |
| pqPythonManager * | pythonManager () const |
| Provides access to the python manager. More... | |
| virtual void | registerForQuicklaunch (QWidget *) |
| ParaView provides a mechanism to trigger menu actions using a quick-launch dialog. More... | |
| void | loadStateFromPythonFile (const QString &filename, pqServer *server) |
Public Member Functions inherited from pqApplicationCore | |
| pqApplicationCore (int &argc, char **argv, pqOptions *options=0, QObject *parent=0) | |
| Preferred constructor. More... | |
| pqOptions * | getOptions () const |
| Provides access to the command line options object. More... | |
| pqObjectBuilder * | getObjectBuilder () const |
| Get the Object Builder. More... | |
| void | setUndoStack (pqUndoStack *stack) |
| Set/Get the application's central undo stack. More... | |
| pqUndoStack * | getUndoStack () const |
| void | registerManager (const QString &function, QObject *manager) |
| Custom Applications may need use various "managers" All such manager can be registered with the pqApplicationCore so that that can be used by other components of the application. More... | |
| QObject * | manager (const QString &function) |
| Returns a manager for a particular function, if any. More... | |
| void | unRegisterManager (const QString &function) |
| Unregisters a manager for a particular function, if any. More... | |
| void | registerDocumentation (const QString &filename) |
| QHelpEngine doesn't like filenames in resource space. More... | |
| pqServerManagerObserver * | getServerManagerObserver () |
| ServerManagerObserver observer the vtkSMProxyManager for changes to the server manager and fires signals on certain actions such as registeration/unregistration of proxies etc. More... | |
| pqServerManagerModel * | getServerManagerModel () const |
| ServerManagerModel is the representation of the ServerManager using pqServerManagerModelItem subclasses. More... | |
| pqInterfaceTracker * | interfaceTracker () const |
| Locates the interface tracker for the application. More... | |
| pqLinksModel * | getLinksModel () const |
| pqLinksModel is the model used to keep track of proxy/property links maintained by vtkSMProxyManager. More... | |
| pqMainWindowEventManager * | getMainWindowEventManager () const |
| pqMainWindowManager manages signals called for main window events. More... | |
| pqPluginManager * | getPluginManager () const |
| pqPluginManager manages all functionality associated with loading plugins. More... | |
| pqProgressManager * | getProgressManager () const |
| ProgressManager is the manager that streamlines progress. More... | |
| pqRecentlyUsedResourcesList & | recentlyUsedResources () |
| Returns the set of recently-used resources i.e. More... | |
| pqServerConfigurationCollection & | serverConfigurations () |
| Returns the collection of server configurations known. More... | |
| pqSettings * | settings () |
| Get the application settings. More... | |
| void | clearSettings () |
| Clears the settings. More... | |
| vtkPVXMLElement * | saveState () |
| Save the ServerManager state to a XML element. More... | |
| bool | saveState (const QString &filename) |
| Save the ServerManager state to a file. More... | |
| void | loadState (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=NULL) |
| Loads the ServerManager state. More... | |
| void | loadState (const char *filename, pqServer *server, vtkSMStateLoader *loader=NULL) |
| Load state xml from a file. More... | |
| void | loadStateFromString (const char *xmlcontents, pqServer *server, vtkSMStateLoader *loader=NULL) |
| Loads state from an in-memory buffer. More... | |
| void | clearViewsForLoadingState (pqServer *server) |
| void | loadStateIncremental (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=NULL) |
| Same as loadState() except that it doesn't clear the current visualization state. More... | |
| void | loadStateIncremental (const QString &filename, pqServer *server, vtkSMStateLoader *loader=NULL) |
| void | setLoadingState (bool value) |
| Set the loading state flag. More... | |
| bool | isLoadingState () |
| Check to see if its in the process of loading a state Reliance on this flag is chimerical since we cannot set this ivar when state file is being loaded from python shell. More... | |
| pqServer * | getActiveServer () const |
| returns the active server is any. More... | |
| ~pqApplicationCore () override | |
| Destructor. More... | |
| void | _paraview_client_environment_complete () |
| INTERNAL. More... | |
| static pqPVApplicationCore * | instance () |
| Returns the pqPVApplicationCore instance. More... | |
Static Public Member Functions inherited from pqApplicationCore | |
| static pqApplicationCore * | instance () |
| bool | eventFilter (QObject *obj, QEvent *event) override |
| Override event filter in order to catch file association mechanism. More... | |
Protected Attributes | |
| QPointer< pqSelectionManager > | SelectionManager |
| QPointer< pqAnimationManager > | AnimationManager |
| pqPythonManager * | PythonManager |
| QList< QPointer< QWidget > > | QuickLaunchMenus |
Protected Attributes inherited from pqApplicationCore | |
| bool | LoadingState |
| pqOptions * | Options |
| pqLinksModel * | LinksModel |
| pqObjectBuilder * | ObjectBuilder |
| pqInterfaceTracker * | InterfaceTracker |
| pqMainWindowEventManager * | MainWindowEventManager |
| pqPluginManager * | PluginManager |
| pqProgressManager * | ProgressManager |
| pqServerManagerModel * | ServerManagerModel |
| pqServerManagerObserver * | ServerManagerObserver |
| pqUndoStack * | UndoStack |
| pqRecentlyUsedResourcesList * | RecentlyUsedResourcesList |
| pqServerConfigurationCollection * | ServerConfigurations |
| pqSettings * | Settings |
| QPointer< pqTestUtility > | TestUtility |
Protected Slots inherited from pqApplicationCore | |
| void | onStateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator) |
| void | onStateSaved (vtkPVXMLElement *root) |
| void | onHelpEngineWarning (const QString &) |
Definition at line 53 of file pqPVApplicationCore.h.
inlinestatic |
If no pqPVApplicationCore has been created then return NULL.
Definition at line 66 of file pqPVApplicationCore.h.
| pqSelectionManager* pqPVApplicationCore::selectionManager | ( | ) | const |
Selection manager provides access to the ParaView wide data selection mechanism. This must not be confused with the active-object selection.
| pqAnimationManager* pqPVApplicationCore::animationManager | ( | ) | const |
Animation manager helps with the
Reimplemented from pqApplicationCore.
| pqPythonManager* pqPVApplicationCore::pythonManager | ( | ) | const |
This is non-null only when paraview is compiled with python support i.e. PARAVIEW_USE_PYTHON is ON.
Applications can register menus action from which should be launch-able from the quick-launch dialog. Typical candidates are the sources menu, filters menu etc.
slot |
slot |
signal |
This can be used to update the menu items (QActions) that will be shown in the quick-launch dialog.
Definition at line 130 of file pqPVApplicationCore.h.
Definition at line 131 of file pqPVApplicationCore.h.
Definition at line 133 of file pqPVApplicationCore.h.
Definition at line 134 of file pqPVApplicationCore.h.
