pqSelectionManager is the nexus for introspective surface selection in paraview. More...
#include <pqSelectionManager.h>
Inherits QObject.
Public Slots | |
| void | clearSelection (pqOutputPort *outputPort=NULL) |
| Clear selection on a pqOutputPort. More... | |
| void | setActiveView (pqView *) |
| Used to keep track of active render module. More... | |
| void | select (pqOutputPort *) |
| Updates the selected port. More... | |
| void | onSourceAdded (pqPipelineSource *) |
| Set up signal/slot from the pipeline source to the selection manager. More... | |
| void | onSourceRemoved (pqPipelineSource *) |
| Disconnect signal/slot from the pipeline source to the selection manager. More... | |
| void | expandSelection (int layers) |
| Expand/contract selection to include additional layers. More... | |
Signals | |
| void | selectionChanged (pqOutputPort *) |
| Fired when the selection changes. More... | |
| pqSelectionManager (QObject *parent=NULL) | |
| ~pqSelectionManager () override | |
| pqOutputPort * | getSelectedPort () const |
| Returns the first currently selected pqOutputPort, if any. More... | |
| const QSet< pqOutputPort * > & | getSelectedPorts () const |
| Return all currently selected pqOutputPort as a QSet, or an empty QSet if there aren't any. More... | |
| bool | hasActiveSelection () const |
| Return true if there is at least one currently selected pqOutputPort false otherwise. More... | |
| vtkBoundingBox | selectedDataBounds () const |
| Returns the bounding box for all the selected data. More... | |
| void | onSelect (pqOutputPort *, bool forceGlobalIds) |
It responds to UI events to tell the servermanager to setup for making selections. It watches the servermanager's state to see if the selection parameters are changed (either from the UI or from playback) and tells the servermanager to perform the requested selection. It is also the link between the server manager level selection and the GUI, converting servermanager selection result datastructures into pq/Qt level selection datastructures so that all views can be synchronized and show the same selection in their own manner.
Definition at line 68 of file pqSelectionManager.h.
| pqSelectionManager::pqSelectionManager | ( | QObject * | parent = NULL | ) |
| pqOutputPort* pqSelectionManager::getSelectedPort | ( | ) | const |
| const QSet<pqOutputPort*>& pqSelectionManager::getSelectedPorts | ( | ) | const |
| bool pqSelectionManager::hasActiveSelection | ( | ) | const |
| vtkBoundingBox pqSelectionManager::selectedDataBounds | ( | ) | const |
signal |
Argument is the pqOutputPort (if any) that was selected. If selection was cleared then the argument is NULL.
slot |
Calling the method without arguments or with null will clear all selection
slot |
slot |
slot |
slot |
slot |
