pqOptions.h
3  Program: ParaView
4  Module: pqOptions.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32
33 #ifndef pqOptions_h
34 #define pqOptions_h
35
36 #include "pqCoreModule.h"
37 #include <QStringList>
38 #include <vtkPVOptions.h>
45 class PQCORE_EXPORT pqOptions : public vtkPVOptions
46 {
47 public:
48  static pqOptions* New();
49  vtkTypeMacro(pqOptions, vtkPVOptions);
50  void PrintSelf(ostream& os, vtkIndent indent) override;
51
52  vtkGetStringMacro(BaselineDirectory);
53  vtkGetStringMacro(TestDirectory);
54  vtkGetStringMacro(DataDirectory);
55
57
60  // See Bug #5711
61  vtkGetStringMacro(StateFileName);
63
64  vtkGetMacro(ExitAppWhenTestsDone, int);
65
66  // Returns the test scripts as a list.
67  QStringList GetTestScripts();
68
73  vtkGetStringMacro(ServerResourceName);
74
75  vtkSetStringMacro(BaselineDirectory);
76  vtkSetStringMacro(TestDirectory);
77  vtkSetStringMacro(DataDirectory);
78
79  int GetNumberOfTestScripts() { return this->TestScripts.size(); }
80  QString GetTestScript(int cc) { return this->TestScripts[cc].TestFile; }
81  QString GetTestBaseline(int cc) { return this->TestScripts[cc].TestBaseline; }
82  int GetTestImageThreshold(int cc) { return this->TestScripts[cc].ImageThreshold; }
83
89  vtkSetMacro(CurrentImageThreshold, int);
90  vtkGetMacro(CurrentImageThreshold, int);
91
92  // Description:
93  // These flags are used for testing multi-clients configurations.
94  vtkGetMacro(TestMaster, int);
95  vtkGetMacro(TestSlave, int);
96
97  // Description:
98  // Using --script option, user can specify a python script to be run on
99  // startup. This have any effect only when ParaView is built with Python
100  // support.
101  vtkGetStringMacro(PythonScript);
102
103  // DO NOT CALL. Public for internal callbacks.
104  int AddTestScript(const char*);
105  int SetLastTestBaseline(const char*);
106  int SetLastTestImageThreshold(int);
107
108 protected:
109  pqOptions();
110  ~pqOptions() override;
111
112  void Initialize() override;
113  int PostProcess(int argc, const char* const* argv) override;
114
119  char* StateFileName; // loading state file(Bug #5711)
120
127
128  vtkSetStringMacro(PythonScript);
129  vtkSetStringMacro(ServerResourceName);
130  vtkSetStringMacro(StateFileName);
131
132  struct TestInfo
133  {
134  QString TestFile;
135  QString TestBaseline;
138  : ImageThreshold(12)
139  {
140  }
141  };
142
143  QList<TestInfo> TestScripts;
144
145  // Description:
146  // This method is called when wrong argument is found. If it returns 0, then
147  // the parsing will fail.
148  int WrongArgument(const char* argument) override;
149
150 private:
151  pqOptions(const pqOptions&);
152  void operator=(const pqOptions&);
153 };
154
155 #endif // pqOptions_h
int DisableRegistry
Definition: pqOptions.h:122
char * DataDirectory
Definition: pqOptions.h:117
QList< TestInfo > TestScripts
Definition: pqOptions.h:143
Definition: pqOptions.h:135
int ExitAppWhenTestsDone
Definition: pqOptions.h:121
int PostProcess(int argc, const char *const *argv) override
After parsing, process extra option dependencies.
char * StateFileName
Definition: pqOptions.h:119
char * TestDirectory
Definition: pqOptions.h:116
int TestMaster
Definition: pqOptions.h:124
Initialize arguments.
int TestSlave
Definition: pqOptions.h:125
char * ServerResourceName
Definition: pqOptions.h:118
Definition: pqOptions.h:80
char * BaselineDirectory
Definition: pqOptions.h:115
char * PythonScript
Definition: pqOptions.h:126
Definition: pqOptions.h:82
int CurrentImageThreshold
Definition: pqOptions.h:123
Definition: pqOptions.h:81
Definition: pqOptions.h:79
ParaView options storage.
Definition: vtkPVOptions.h:37
Command line options for pqClient.
Definition: pqOptions.h:45
static vtkPVOptions * New()
