32 #ifndef pqApplicationCore_h 33 #define pqApplicationCore_h 35 #include "pqCoreModule.h" 58 #ifdef PARAVIEW_USE_QTHELP 79 typedef QObject Superclass;
124 void registerManager(
const QString&
function, QObject* manager);
130 QObject* manager(
const QString&
function);
135 void unRegisterManager(
const QString&
function);
137 #ifdef PARAVIEW_USE_QTHELP 142 QHelpEngine* helpEngine();
149 void registerDocumentation(
const QString& filename);
188 return this->MainWindowEventManager;
204 virtual pqTestUtility* testUtility();
231 void clearSettings();
242 bool saveState(
260 void loadStateFromString(
263 void clearViewsForLoadingState(
pqServer* server);
269 void loadStateIncremental(
271 void loadStateIncremental(
299 void _paraview_client_environment_complete();
307 void prepareForQuit();
319 void loadConfiguration(
320 void loadConfigurationXML(
const char* xmldata);
364 void forceFilterMenuRefresh();
369 void updateMasterEnableState(
bool);
375 void clientEnvironmentDone();
380 void onHelpEngineWarning(
const QString&);
388 void generalSettingsChanged();
406 #ifdef PARAVIEW_USE_QTHELP 407 QHelpEngine* HelpEngine;
415 pqInternals* Internal;
pqProgressManager * ProgressManager
pqLinksModel * LinksModel
pqServerManagerObserver * ServerManagerObserver
This class is the crux of the ParaView application.
void setLoadingState(bool value)
Set the loading state flag.
pqInterfaceTracker * interfaceTracker() const
Locates the interface tracker for the application.
manages recently used resources
A Qt based model to represent the vtkSMLinks in the server manager.
pqPluginManager * PluginManager
pqRecentlyUsedResourcesList * RecentlyUsedResourcesList
pqPluginManager * getPluginManager() const
pqPluginManager manages all functionality associated with loading plugins.
pqProgressManager is progress manager.
pqObjectBuilder is loosely based on the Builder design pattern.
pqProgressManager * getProgressManager() const
ProgressManager is the manager that streamlines progress.
pqServerManagerModel * ServerManagerModel
pqServerManagerObserver * getServerManagerObserver()
ServerManagerObserver observer the vtkSMProxyManager for changes to the server manager and fires sign...
pqInterfaceTracker * InterfaceTracker
pqMainWindowEventManager is a manager for marshalling a main window's events to pqReactions.
pqServerConfigurationCollection maintains a serializable collection of server-configurations defined ...
pqSettings extends QSettings to add support for following:
This is a vtkSMProxyManager observer.
pqServerConfigurationCollection * ServerConfigurations
QPointer< pqTestUtility > TestUtility
pqObjectBuilder * ObjectBuilder
pqServerManagerModel is the model for the Server Manager.
bool isLoadingState()
Check to see if its in the process of loading a state Reliance on this flag is chimerical since we ca...
pqObjectBuilder * getObjectBuilder() const
Get the Object Builder.
pqOptions * getOptions() const
Provides access to the command line options object.
PQ representation for a vtkSMProxy that can be involved in a pipeline.
pqServerManagerModel * getServerManagerModel() const
ServerManagerModel is the representation of the ServerManager using pqServerManagerModelItem subclass...
pqMainWindowEventManager * MainWindowEventManager
Utility class to load state from XML.
pqUndoStack * getUndoStack() const
pqUndoStack represents a vtkSMUndoStack along with a a vtkSMUndoStackBuilder.
Command line options for pqClient.
pqLinksModel * getLinksModel() const
pqLinksModel is the model used to keep track of proxy/property links maintained by vtkSMProxyManager...
pqInterfaceTracker is used by ParaView components to locate interface-implementations.
pqServerResource encapsulates a resource in ParaView.
pqPluginManager works with vtkSMPluginManager to keep track for plugins loaded/available.
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
pqMainWindowEventManager * getMainWindowEventManager() const
pqMainWindowManager manages signals called for main window events.
