pqMultiQueryClauseWidget.h
3  Program: ParaView
4  Module: pqMultiQueryClauseWidget.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqMultiQueryClauseWidget_h
33 #define pqMultiQueryClauseWidget_h
35 #include "pqComponentsModule.h"
36 #include <QWidget>
37
38 class pqOutputPort;
42 class vtkSMProxy;
43 class QScrollArea;
49 class PQCOMPONENTS_EXPORT pqMultiQueryClauseWidget : public QWidget
50 {
51  Q_OBJECT
52  typedef QWidget Superclass;
53
54 public:
55  pqMultiQueryClauseWidget(QWidget* parent = nullptr, Qt::WindowFlags flags = Qt::WindowFlags{});
56  ~pqMultiQueryClauseWidget() override = default;
57
59
62  void setProducer(pqOutputPort* p) { this->Producer = p; }
63  pqOutputPort* producer() const { return this->Producer; }
65
67
72  void setAttributeType(int attrType) { this->AttributeType = attrType; }
73  int attributeType() const { return this->AttributeType; }
75
80  void initialize();
81
85  bool isAMR();
86
90  bool isMultiBlock();
91
97  vtkSMProxy* newSelectionSource();
98
102  vtkPVDataSetAttributesInformation* getChosenAttributeInfo() const;
103
104 protected Q_SLOTS:
108  void addQueryClauseWidget();
109
113  void onChildrenChanged();
114
115 protected:
120  void updateDependentClauseWidgets();
121
126  void addQueryClauseWidget(int type, bool qualifier_mode);
127
133
134  QWidget* Container;
135  QScrollArea* ScrollArea;
136
137 private:
138  Q_DISABLE_COPY(pqMultiQueryClauseWidget)
139 };
140
141 #endif
void setProducer(pqOutputPort *p)
Set/Get the data producer.
Set the attribute type.
pqOutputPort is a server manager model item for an output port of any pqPipelineSource item...
Definition: pqOutputPort.h:58
pqQueryClauseWidget is used by pqQueryDialog as the widget allowing the user choose the clauses for t...
type
Light object for holding data information.
pqMultiQueryClauseWidget is used by pqQueryDialog as the widget allowing the user choose the clauses ...
pqOutputPort * producer() const
Definition: vtkSMProxy.h:152
