pqQueryClauseWidget is used by pqQueryDialog as the widget allowing the user choose the clauses for the queries.
#include <pqQueryClauseWidget.h>
Inherits QWidget.
| enum | CriteriaType {
INVALID = 0x0,
INDEX = 0x1,
GLOBALID = 0x2,
THRESHOLD = 0x4,
BLOCK = 0x10,
AMR_LEVEL = 0x20,
AMR_BLOCK = 0x40,
PROCESSID = 0x80,
QUERY = 0x8,
POINTS_NEAR = 0x100,
POINT_IN_CELL = 0x200,
ANY = 0xffff
| enum | ConditionMode {
SINGLE_VALUE,
SINGLE_VALUE_GE,
SINGLE_VALUE_LE,
PAIR_OF_VALUES,
TRIPLET_OF_VALUES,
LIST_OF_VALUES,
BLOCK_ID_VALUE,
LIST_OF_BLOCK_ID_VALUES,
BLOCK_NAME_VALUE,
AMR_LEVEL_VALUE,
AMR_BLOCK_VALUE,
SINGLE_VALUE_MIN,
SINGLE_VALUE_MAX,
SINGLE_VALUE_NAN,
SINGLE_VALUE_LE_MEAN,
SINGLE_VALUE_GE_MEAN,
SINGLE_VALUE_MEAN_WITH_TOLERANCE,
LOCATION_AND_TOLERANCE,
LOCATION
| enum | DataSetType { DataSetType::STANDARD,
DataSetType::AMR,
DataSetType::MULTIBLOCK
Definition at line 48 of file pqQueryClauseWidget.h.
◆ CriteriaType
| Enumerator |
| INVALID | |
| INDEX | |
| GLOBALID | |
| THRESHOLD | |
| BLOCK | |
| AMR_LEVEL | |
| AMR_BLOCK | |
| PROCESSID | |
| QUERY | |
| POINTS_NEAR | |
| POINT_IN_CELL | |
| ANY | |
Definition at line 54 of file pqQueryClauseWidget.h.
◆ ConditionMode
| Enumerator |
| SINGLE_VALUE | |
| SINGLE_VALUE_GE | |
| SINGLE_VALUE_LE | |
| PAIR_OF_VALUES | |
| TRIPLET_OF_VALUES | |
| LIST_OF_VALUES | |
| BLOCK_ID_VALUE | |
| LIST_OF_BLOCK_ID_VALUES | |
| BLOCK_NAME_VALUE | |
| AMR_LEVEL_VALUE | |
| AMR_BLOCK_VALUE | |
| SINGLE_VALUE_MIN | |
| SINGLE_VALUE_MAX | |
| SINGLE_VALUE_NAN | |
| SINGLE_VALUE_LE_MEAN | |
| SINGLE_VALUE_GE_MEAN | |
| SINGLE_VALUE_MEAN_WITH_TOLERANCE | |
| LOCATION_AND_TOLERANCE | |
| LOCATION | |
Definition at line 72 of file pqQueryClauseWidget.h.
◆ DataSetType
◆ pqQueryClauseWidget()
| pqQueryClauseWidget::pqQueryClauseWidget |
pqMultiQueryClauseWidget * |
multiQueryWidget, |
QWidget * |
parent = nullptr, |
Qt::WindowFlags |
flags = Qt::WindowFlags{} |
◆ ~pqQueryClauseWidget()
| pqQueryClauseWidget::~pqQueryClauseWidget |
◆ Q_DECLARE_FLAGS()
| pqQueryClauseWidget::Q_DECLARE_FLAGS |
CriteriaTypes |
CriteriaType |
◆ initialize [1/2]
| void pqQueryClauseWidget::initialize |
inlineslot |
use this slot to initialize the clause GUI after all properties have been set.
FIXME: Unsupported Terms: process id, amr-level, amr-block. We will need to extend VTK selection support for those, so we will implement them later (possibly 3.10/4.0)
Definition at line 115 of file pqQueryClauseWidget.h.
◆ initialize [2/2]
CriteriaTypes |
type_flags, |
bool |
qualifier_mode = false |
slot |
initialize the widget only with the subset of criteria mentioned.
A query clause has two components, the query term and the qualifiers. Some criteria can be both eg. BLOCK can be both the term or a qualifier. The available operators may change in such case. Hence, we specify if it's being used as a qualifier or not.
◆ addSelectionQualifiers
| void pqQueryClauseWidget::addSelectionQualifiers |
vtkSMProxy * |
slot |
Updates the selection source proxy with the criteria in the clause.
◆ setAddButtonVisible
| void pqQueryClauseWidget::setAddButtonVisible |
bool |
show | ) |
slot |
Set the Add button visibility.
◆ setRemoveButtonVisible
| void pqQueryClauseWidget::setRemoveButtonVisible |
bool |
show | ) |
slot |
Set the Remove button visibility.
◆ setAndLabelVisible
| void pqQueryClauseWidget::setAndLabelVisible |
bool |
show | ) |
slot |
Set the And label visibility.
◆ addQueryRequested
| void pqQueryClauseWidget::addQueryRequested |
signal |
Emited when user ask for a new query.
◆ populateSelectionCondition
| void pqQueryClauseWidget::populateSelectionCondition |
protectedslot |
Based on the selection criteria, populate the options in the selection "condition" combo box.
◆ updateValueWidget
| void pqQueryClauseWidget::updateValueWidget |
protectedslot |
Update the value widget so show the correct widget based on the chosen criteria and condition.
◆ showCompositeTree
| void pqQueryClauseWidget::showCompositeTree |
protectedslot |
Pops up a dialog showing the composite data structure for the data.
◆ deleteQuery
| void pqQueryClauseWidget::deleteQuery |
protectedslot |
Deletes this widget and notifies parent.
◆ populateSelectionCriteria()
| void pqQueryClauseWidget::populateSelectionCriteria |
CriteriaTypes |
type = ANY | ) |
Based on the selection type and data information from the producer, populate the "criteria" combo box.
◆ currentCriteriaType()
| CriteriaType pqQueryClauseWidget::currentCriteriaType |
const |
Returns the current criteria type.
◆ currentConditionType()
| ConditionMode pqQueryClauseWidget::currentConditionType |
const |
Returns the current condition type.
◆ AttributeType
| int pqQueryClauseWidget::AttributeType |
◆ AsQualifier
| bool pqQueryClauseWidget::AsQualifier |
◆ LastQuery
| QString pqQueryClauseWidget::LastQuery |
◆ MultiQueryWidget
