pqMultiQueryClauseWidget is used by pqQueryDialog as the widget allowing the user choose the clauses for the queries.
#include <pqMultiQueryClauseWidget.h>
Inherits QWidget.
Definition at line 49 of file pqMultiQueryClauseWidget.h.
◆ pqMultiQueryClauseWidget()
| pqMultiQueryClauseWidget::pqMultiQueryClauseWidget |
QWidget * |
parent = nullptr, |
Qt::WindowFlags |
flags = Qt::WindowFlags{} |
◆ ~pqMultiQueryClauseWidget()
| pqMultiQueryClauseWidget::~pqMultiQueryClauseWidget |
overridedefault |
◆ setProducer()
| void pqMultiQueryClauseWidget::setProducer |
pqOutputPort * |
p | ) |
◆ producer()
◆ setAttributeType()
| void pqMultiQueryClauseWidget::setAttributeType |
int |
attrType | ) |
◆ attributeType()
| int pqMultiQueryClauseWidget::attributeType |
const |
◆ initialize()
| void pqMultiQueryClauseWidget::initialize |
Initialize the widget : remove all existent pqQueryClauseWidgets and create an empty one.
Add relevant dependant clause widget.
◆ isAMR()
| bool pqMultiQueryClauseWidget::isAMR |
return true if input data is of type AMR.
◆ isMultiBlock()
| bool pqMultiQueryClauseWidget::isMultiBlock |
return true if input data is of type MultiBlock.
◆ newSelectionSource()
| vtkSMProxy* pqMultiQueryClauseWidget::newSelectionSource |
Creates a new selection source proxy based on the query.
Note that this does not register the proxy, it merely creates the selection source and returns it.
◆ getChosenAttributeInfo()
Returns the attribute info for the current attribute type.
◆ addQueryClauseWidget [1/2]
| void pqMultiQueryClauseWidget::addQueryClauseWidget |
protectedslot |
Adds a default query clause widget.
◆ onChildrenChanged
| void pqMultiQueryClauseWidget::onChildrenChanged |
protectedslot |
Update visibility and connections.
◆ updateDependentClauseWidgets()
| void pqMultiQueryClauseWidget::updateDependentClauseWidgets |
Some query clauses under certain conditions require additional options from the user.
For instance, if input is a multiblock we add a BLOCKID clause.
◆ addQueryClauseWidget() [2/2]
int |
type, |
bool |
qualifier_mode |
Adds a query clause widget.
- Parameters
◆ Producer
◆ AttributeType
| int pqMultiQueryClauseWidget::AttributeType |
◆ ChildNextId
| int pqMultiQueryClauseWidget::ChildNextId |
◆ NumberOfDependentClauseWidgets
| int pqMultiQueryClauseWidget::NumberOfDependentClauseWidgets |
◆ AddingClauseWidget
| bool pqMultiQueryClauseWidget::AddingClauseWidget |
◆ Container
| QWidget* pqMultiQueryClauseWidget::Container |
◆ ScrollArea
| QScrollArea* pqMultiQueryClauseWidget::ScrollArea |
