pqLinksModel.h
3  Program: ParaView
4  Module: pqLinksModel.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32
33 #ifndef _pqLinksModel_h
34 #define _pqLinksModel_h
35
36 #include "pqCoreModule.h"
37 #include <QAbstractItemModel>
38
39 class vtkCollection;
41 class pqProxy;
42 class pqRenderView;
43 class pqServer;
45 class vtkSMLink;
46 class vtkSMProxy;
48 class vtkSMProxyLocator;
49 class vtkPVXMLElement;
50
56 class PQCORE_EXPORT pqLinksModel : public QAbstractTableModel
57 {
58  Q_OBJECT
59  typedef QAbstractTableModel Superclass;
60
61 public:
65  enum ItemType
66  {
71  Selection
72  };
73
74 public:
78  pqLinksModel(QObject* parent = 0);
79
83  ~pqLinksModel() override;
84
85  // implementation to satisfy api
89  int rowCount(const QModelIndex& parent = QModelIndex()) const override;
93  int columnCount(const QModelIndex& parent = QModelIndex()) const override;
97  QVariant data(const QModelIndex& index, int role = Qt::DisplayRole) const override;
101  QVariant headerData(
102  int section, Qt::Orientation orient, int role = Qt::DisplayRole) const override;
103
104  // subclass specific implementation
108  ItemType getLinkType(const QModelIndex& idx) const;
112  vtkSMLink* getLink(const QModelIndex& idx) const;
116  QModelIndex findLink(vtkSMLink* link) const;
117
122  int FindLinksFromProxy(vtkSMProxy* inputProxy, int direction, vtkCollection* links) const;
123
127  vtkSMProxy* getProxy1(const QModelIndex& idx) const;
131  vtkSMProxy* getProxy2(const QModelIndex& idx) const;
132
136  QString getProperty1(const QModelIndex& idx) const;
140  QString getProperty2(const QModelIndex& idx) const;
141
145  QString getLinkName(const QModelIndex& idx) const;
149  vtkSMLink* getLink(const QString& name) const;
150
154  void addProxyLink(const QString& name, vtkSMProxy* proxy1, vtkSMProxy* proxy2);
155
159  void addCameraLink(
160  const QString& name, vtkSMProxy* proxy1, vtkSMProxy* proxy2, bool interactiveViewLink = false);
161
165  bool hasInteractiveViewLink(const QString& name);
166
170  pqInteractiveViewLink* getInteractiveViewLink(const QString& name);
171
175  void addPropertyLink(const QString& name, vtkSMProxy* proxy1, const QString& prop1,
176  vtkSMProxy* proxy2, const QString& prop2);
177
181  void addSelectionLink(
182  const QString& name, vtkSMProxy* proxy1, vtkSMProxy* proxy2, bool convertToIndices = true);
183
187  void removeLink(const QModelIndex& idx);
191  void removeLink(const QString& name);
192
198  static pqProxy* representativeProxy(vtkSMProxy* proxy);
199
204  static vtkSMProxyListDomain* proxyListDomain(vtkSMProxy* proxy);
205
206 Q_SIGNALS:
210  void linkAdded(int linkType);
211
215  void linkRemoved(const QString& name);
216
217 protected Q_SLOTS:
218  void onSessionCreated(pqServer*);
219  void onSessionRemoved(pqServer*);
220
225  void onStateLoaded(vtkPVXMLElement* root, vtkSMProxyLocator* locator);
226
231  void onStateSaved(vtkPVXMLElement* root);
232
236  void createInteractiveViewLink(const QString& name, vtkSMProxy* displayView,
237  vtkSMProxy* linkedView, double xPos = 0.375, double yPos = 0.375, double xSize = 0.25,
238  double ySize = 0.25);
239
243  void emitLinkRemoved(const QString& name);
244
245 private:
246  ItemType getLinkType(vtkSMLink* link) const;
247  vtkSMProxy* getProxyFromIndex(const QModelIndex& idx, int dir) const;
248  QString getPropertyFromIndex(const QModelIndex& idx, int dir) const;
249
250  class pqInternal;
251  pqInternal* Internal;
252 };
253
254 // internal class here for moc'ing reasons
255 class pqLinksModelObject : public QObject
256 {
257  Q_OBJECT
258 public:
260  ~pqLinksModelObject() override;
261
262  QString name() const;
263  vtkSMLink* link() const;
264
265 Q_SIGNALS:
266  void linkRemoved();
267
268 private Q_SLOTS:
269  void proxyModified(pqServerManagerModelItem*);
270  void refresh();
271  void remove();
272
273 private:
274  class pqInternal;
275  pqInternal* Internal;
276
277  void linkUndoStacks();
278  void unlinkUndoStacks(pqRenderView*);
279 };
280
281 #endif
data
A Qt based model to represent the vtkSMLinks in the server manager.
Definition: pqLinksModel.h:56
pqServerManagerModelItem is a element maintained by pqServerManagerModel.
ItemType
type of link (camera, proxy or property)
Definition: pqLinksModel.h:65
name
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:56
Definition: vtkSMProxy.h:152
union of proxies.
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
