pqRenderView.h
3  Program: ParaView
4  Module: pqRenderView.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32 #ifndef pqRenderViewModule_h
33 #define pqRenderViewModule_h
35 #include "pqRenderViewBase.h"
36 #include <QColor> // needed for return type.
37
39 class QAction;
40 class vtkCollection;
41 class vtkIntArray;
43
44 // This is a PQ abstraction of a render view.
45 class PQCORE_EXPORT pqRenderView : public pqRenderViewBase
46 {
47  Q_OBJECT
49
50 public:
51  static QString renderViewType() { return "RenderView"; }
52
53  // Constructor:
54  // \c group :- SManager registration group name.
55  // \c name :- SManager registration name.
56  // \c view :- RenderView proxy.
57  // \c server:- server on which the proxy is created.
58  // \c parent:- QObject parent.
59  pqRenderView(const QString& group, const QString& name, vtkSMViewProxy* renModule,
60  pqServer* server, QObject* parent = NULL);
61
62  // This version allows subclasses to substitute their own renderViewType.
63  pqRenderView(const QString& tname, const QString& group, const QString& name,
64  vtkSMViewProxy* renModule, pqServer* server, QObject* parent = NULL);
65
66  // Destructor.
67  ~pqRenderView() override;
68
72  virtual vtkSMRenderViewProxy* getRenderViewProxy() const;
73
79  void resetCamera() override;
80
84  virtual void resetCenterOfRotation();
85
90  virtual void resetParallelScale();
91
95  virtual bool getOrientationAxesVisibility() const;
96
100  virtual bool getOrientationAxesInteractivity() const;
101
105  virtual QColor getOrientationAxesLabelColor() const;
106
110  virtual QColor getOrientationAxesOutlineColor() const;
111
116  virtual bool getResetCenterWithCamera() const { return this->ResetCenterWithCamera; }
117
122  {
123  return this->UseMultipleRepresentationSelection;
124  }
125
129  virtual bool getCenterAxesVisibility() const;
130
134  virtual void getCenterOfRotation(double center[3]) const;
135
141  bool supportsUndo() const override { return true; }
142
147  bool canUndo() const override;
148  bool canRedo() const override;
149
155  bool supportsCapture() const override { return true; }
156
162  virtual void linkUndoStack(pqRenderView* other);
163  virtual void unlinkUndoStack(pqRenderView* other);
164
169  virtual void clearUndoStack();
170
174  virtual void resetViewDirection(
175  double look_x, double look_y, double look_z, double up_x, double up_y, double up_z);
176
183  virtual void setCursor(const QCursor&);
184
189  virtual void selectOnSurface(int rectangle[4],
190  int selectionModifier = pqView::PV_SELECTION_DEFAULT, const char* array = nullptr);
191  virtual void selectPointsOnSurface(int rectangle[4],
192  int selectionModifier = pqView::PV_SELECTION_DEFAULT, const char* array = nullptr);
193
199  virtual pqDataRepresentation* pick(int pos[2]);
200
206  virtual pqDataRepresentation* pickBlock(int pos[2], unsigned int& flatIndex);
207
212  virtual void selectFrustum(int rectangle[4]);
213  virtual void selectFrustumPoints(int rectangle[4]);
214
219  virtual void selectBlock(int rectangle[4], int selectionModifier = pqView::PV_SELECTION_DEFAULT);
220
225  virtual void selectPolygonPoints(
226  vtkIntArray* polygon, int selectionModifier = pqView::PV_SELECTION_DEFAULT);
227
232  virtual void selectPolygonCells(
233  vtkIntArray* polygon, int selectionModifier = pqView::PV_SELECTION_DEFAULT);
234
235 Q_SIGNALS:
236  // Triggered when interaction mode change underneath
237  void updateInteractionMode(int mode);
238
239 public Q_SLOTS:
240  // Toggle the orientation axes visibility.
241  virtual void setOrientationAxesVisibility(bool visible);
242
243  // Toggle orientation axes interactivity.
244  virtual void setOrientationAxesInteractivity(bool interactive);
245
246  // Set orientation axes label color.
247  virtual void setOrientationAxesLabelColor(const QColor&);
248
249  // Set orientation axes outline color.
250  virtual void setOrientationAxesOutlineColor(const QColor&);
251
252  // Set the center of rotation. For this to work,
253  // one should have appropriate interaction style (vtkPVInteractorStyle subclass)
254  // and camera manipulators that use the center of rotation.
255  // They are setup correctly by default.
256  virtual void setCenterOfRotation(double x, double y, double z);
257  virtual void setCenterOfRotation(double xyz[3])
258  {
259  this->setCenterOfRotation(xyz[0], xyz[1], xyz[2]);
260  }
261
262  // Set the parallel scale
263  virtual void setParallelScale(double scale);
264
265  // Toggle center axes visibility.
266  virtual void setCenterAxesVisibility(bool visible);
267
272  virtual void setResetCenterWithCamera(bool b) { this->ResetCenterWithCamera = b; }
273
278  {
279  this->UseMultipleRepresentationSelection = b;
280  }
281
285  virtual void linkToOtherView();
286
291  virtual void undo() override;
292
297  virtual void redo() override;
298
302  virtual void resetCenterOfRotationIfNeeded() { this->onResetCameraEvent(); }
303
307  virtual void updateInteractionMode(pqOutputPort* opPort);
308
309 protected Q_SLOTS:
313  virtual void onInteractionModeChange();
314
318  virtual void onGenericFilmicPresetsChange();
319
320  // Called when vtkSMRenderViewProxy fires
321  // ResetCameraEvent.
322  virtual void onResetCameraEvent();
323
328  virtual void onUndoStackChanged();
329
330 protected:
334  virtual void fakeUndoRedo(bool redo, bool self);
335
341  virtual void fakeInteraction(bool start);
342
347  QWidget* createWidget() override;
348
352  void initialize() override;
353
354  // When true, the camera center of rotation will be reset when the
355  // user reset the camera.
357
358  // When true, the selection will be performed on all representations.
360
361 private:
362  void selectOnSurfaceInternal(int rect[4], QList<pqOutputPort*>&, bool select_points,
363  int selectionModifier, bool select_blocks, const char* array = nullptr);
364
365  void selectPolygonInternal(vtkIntArray* polygon, QList<pqOutputPort*>&, bool select_points,
366  int selectionModifier, bool select_blocks);
367
368  void emitSelectionSignal(QList<pqOutputPort*> outputPorts, int selectionModifier);
369
370  void collectSelectionPorts(vtkCollection* selectedRepresentations,
371  vtkCollection* selectionSources, QList<pqOutputPort*>& pqPorts, int selectionModifier,
372  bool select_blocks);
373
374  void InternalConstructor(vtkSMViewProxy* renModule);
375
376  class pqInternal;
377  pqInternal* Internal;
378 };
379
380 #endif
pqDataRepresentation is the superclass for a display for a pqPipelineSource i.e.
pqOutputPort is a server manager model item for an output port of any pqPipelineSource item...
Definition: pqOutputPort.h:58
virtual void resetCamera()=0
Resets the camera to include all visible data.
Use this method to initialize the pqObject state using the underlying vtkSMProxy. ...
virtual void redo()
Called to redo interaction.
Definition: pqView.h:139
Superclass for all view proxies.
bool UseMultipleRepresentationSelection
Definition: pqRenderView.h:359
QWidget * createWidget() override
Creates a new instance of the QWidget subclass to be used to show this view.
Returns if this view module can support undo/redo.
Definition: pqRenderView.h:141
virtual void setUseMultipleRepresentationSelection(bool b)
Set whether selection will be done on multiple representations.
Definition: pqRenderView.h:277
name
Returns if this view module can support image capture.
Definition: pqRenderView.h:155
Get/Set whether resetCamera() resets the center of rotation as well.
Definition: pqRenderView.h:272
Resets center of rotation if this->ResetCenterWithCamera is true.
Definition: pqRenderView.h:302
virtual bool getUseMultipleRepresentationSelection() const
Get whether selection will be done on multiple representations.
Definition: pqRenderView.h:121
virtual bool canUndo() const
Returns true if undo can be done.
Definition: pqView.h:152
implementation for View that includes render window and renderers.
Definition: pqRenderView.h:257
Get whether resetCamera() resets the center of rotation as well.
Definition: pqRenderView.h:116
mode
virtual bool canRedo() const
Returns true if redo can be done.
Definition: pqView.h:157
pqRenderViewBase is an abstract base class for all render-view based views.
virtual void undo()
Called to undo interaction.
Definition: pqView.h:133
bool ResetCenterWithCamera
Definition: pqRenderView.h:356
center
scale
Definition: pqRenderView.h:51
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
