pqInteractiveViewLink.h
3  Program: ParaView
4  Module: pqInteractiveViewLink.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32 #ifndef pqInteractiveViewLink_h
33 #define pqInteractiveViewLink_h
35 #include "pqCoreModule.h"
36 #include <QObject>
37
38 class pqRenderView;
39 class vtkPVXMLElement;
40
46 class PQCORE_EXPORT pqInteractiveViewLink : public QObject
47 {
48  Q_OBJECT;
49  typedef QObject Superclass;
50
51 public:
52  pqInteractiveViewLink(pqRenderView* displayView, pqRenderView* linkedView, double xPos = 0.375,
53  double yPos = 0.375, double xSize = 0.25, double ySize = 0.25);
54  ~pqInteractiveViewLink() override;
55
56  // Save this interactive view link in xml node
57  virtual void saveXMLState(vtkPVXMLElement* xml);
58
59  // Set/Get the view link opacity, between 0 and 1
60  virtual void setOpacity(double opacity);
61  virtual double getOpacity();
62
63  // Set/get whether to hide the background of the linked view
64  virtual void setHideLinkedViewBackground(bool hide);
65  virtual bool getHideLinkedViewBackground();
66
67 protected:
68  // Generate a correct draw method call from current situation
69  // on the back buffer
70  virtual void drawViewLink();
71
72  // draw pixels on the display Window at ViewLink position
73  virtual void drawViewLink(int setFront);
74
75  // update the linked window
76  virtual void renderLinkedView();
77
78  // method to set rendered flag to true
79  virtual void linkedWindowRendered();
80
81 protected Q_SLOTS:
82
83  // draw pixels on the front buffer
84  virtual void finalRenderDisplayView();
85
86 private:
87  class pqInternal;
88  pqInternal* Internal;
89 };
90
91 #endif
