pqImplicitPlanePropertyWidget.h
3  Program: ParaView
4  Module: pqImplicitPlanePropertyWidget.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqImplicitPlanePropertyWidget_h
33 #define pqImplicitPlanePropertyWidget_h
36
51 class PQAPPLICATIONCOMPONENTS_EXPORT pqImplicitPlanePropertyWidget
53 {
54  Q_OBJECT
56
57 public:
59  vtkSMProxy* proxy, vtkSMPropertyGroup* smgroup, QWidget* parent = 0);
61
65  void apply() override;
66  void reset() override;
67
68 public Q_SLOTS:
72  void showPlane() { this->setDrawPlane(true); }
73  void hidePlane() { this->setDrawPlane(false); }
74  void setDrawPlane(bool val);
75
79  void useXNormal() { this->setNormal(1, 0, 0); }
80
84  void useYNormal() { this->setNormal(0, 1, 0); }
85
89  void useZNormal() { this->setNormal(0, 0, 1); }
90
94  void resetToDataBounds();
95
99  void resetCameraToNormal();
100
104  void useCameraNormal();
105
106 protected Q_SLOTS:
110  void placeWidget() override;
111
112 private Q_SLOTS:
113  void setOrigin(double x, double y, double z);
114
115 private:
116  Q_DISABLE_COPY(pqImplicitPlanePropertyWidget)
117
118  void setNormal(double x, double y, double z);
119 };
120
121 #endif
void useXNormal()
Set the widget normal to be along the X axis.
void useZNormal()
Set the widget normal to be along the Z axis.
pqImplicitPlanePropertyWidget is a custom property widget that uses "ImplicitPlaneWidgetRepresentatio...
Definition: vtkSMProxy.h:152
void useYNormal()
Set the widget normal to be along the Y axis.
void showPlane()
Slots used to toggle the visibility of the translucent plane.
virtual void placeWidget()=0
Places the interactive widget using current data source information.
pqInteractivePropertyWidget is an abstract pqPropertyWidget subclass designed to serve as the supercl...
virtual void apply()
Overridden to call this->render() to ensure that the widget is redrawn.
