pqInteractivePropertyWidget.h
3  Program: ParaView
4  Module: pqInteractivePropertyWidget.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqInteractivePropertyWidget_h
33 #define pqInteractivePropertyWidget_h
35 #include "pqApplicationComponentsModule.h"
36 #include "pqPropertyWidget.h"
37 #include "pqSMProxy.h"
38 #include "vtkBoundingBox.h"
39 #include <QScopedPointer>
40
41 class vtkObject;
43 class vtkSMPropertyGroup;
56 class PQAPPLICATIONCOMPONENTS_EXPORT pqInteractivePropertyWidget : public pqPropertyWidget
57 {
58  Q_OBJECT
60  Q_PROPERTY(pqSMProxy dataSource READ dataSource WRITE setDataSource);
61
62 public:
63  pqInteractivePropertyWidget(const char* widget_smgroup, const char* widget_smname,
64  vtkSMProxy* proxy, vtkSMPropertyGroup* smgroup, QWidget* parent = 0);
65  ~pqInteractivePropertyWidget() override;
66
70  void reset() override;
71
75  vtkSMNewWidgetRepresentationProxy* widgetProxy() const;
76
80  void setView(pqView* view) override;
81
89  bool isWidgetVisible() const;
90
94  vtkSMProxy* dataSource() const;
95
100  void select() override;
101  void deselect() override;
102
107  vtkBoundingBox dataBounds() const;
108
112  vtkSMPropertyGroup* propertyGroup() const;
113
117  void hideEvent(QHideEvent*) override;
118
122  void showEvent(QShowEvent*) override;
123
124 public Q_SLOTS:
130  void setWidgetVisible(bool val);
131
137  void setDataSource(vtkSMProxy* dataSource);
138
139 protected Q_SLOTS:
143  virtual void placeWidget() = 0;
144
148  void render();
149
150 Q_SIGNALS:
154  void widgetVisibilityToggled(bool);
155
160  void widgetVisibilityUpdated(bool);
161
166  void startInteraction();
167  void interaction();
168  void endInteraction();
169
170  void dummySignal();
171
172 private Q_SLOTS:
178  void updateWidgetVisibility();
179
180 protected:
181  bool VisibleState = true;
182
183 private:
184  void handleUserEvent(vtkObject*, unsigned long, void*);
185
186 private:
187  Q_DISABLE_COPY(pqInteractivePropertyWidget)
188
189  class pqInternals;
190  QScopedPointer<pqInternals> Internals;
191 };
192
193 #endif
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
virtual void deselect()
virtual void select()
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive.
This is a PQ abstraction of a generic view module.
Definition: pqView.h:54
proxy for 3D widgets and their representations in ParaView.
virtual void reset()
virtual void setView(pqView *)
called to set the active view.
Definition: vtkSMProxy.h:152
pqInteractivePropertyWidget is an abstract pqPropertyWidget subclass designed to serve as the supercl...
