pqEnableWidgetDecorator.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqEnableWidgetDecorator_h
33 #define pqEnableWidgetDecorator_h
35 #include "pqApplicationComponentsModule.h"
37 #include "vtkWeakPointer.h"
38
43 class PQAPPLICATIONCOMPONENTS_EXPORT pqEnableWidgetDecorator : public pqBoolPropertyWidgetDecorator
44 {
45  Q_OBJECT
47
48 public:
50
54  bool enableWidget() const override { return this->isBoolProperty(); }
55
56 private:
57  Q_DISABLE_COPY(pqEnableWidgetDecorator)
58 };
59
60 #endif
pqBoolPropertyWidgetDecorator is a base class for enable/disable or show/hide widgets based on the st...
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
overridden from pqPropertyWidget.
pqEnableWidgetDecorator can be used to enable/disable a widget based on the status of another propert...
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
