32 #ifndef pqServerManagerModel_h 33 #define pqServerManagerModel_h 35 #include "pqCoreModule.h" 83 typedef QObject Superclass;
115 void beginRemoveServer(
pqServer* server);
116 void endRemoveServer();
134 return ::pqFindItem<T>(
this, proxy);
144 return ::pqFindItem<T>(
this, id);
153 return ::pqFindItems<T>(
this);
162 return ::pqGetNumberOfItems<T>(
this);
173 return ::pqGetItemAtIndex<T>(
this, index);
183 return ::pqFindItems<T>(
this, server);
195 return ::pqFindItem<T>(
this, name);
202 QList<void*>* list,
pqServer* server = 0);
246 void aboutToRemoveServer(
pqServer* server);
251 void finishedRemovingServer();
269 void preProxyRemoved(
pqProxy*);
287 void preViewAdded(
pqView* view);
288 void viewAdded(
pqView* view);
293 void preViewRemoved(
pqView*);
294 void viewRemoved(
pqView*);
337 void preConnectionRemoved(
358 virtual void onProxyRegistered(
const QString& group,
const QString& name,
vtkSMProxy* proxy);
363 virtual void onProxyUnRegistered(
vtkSMProxy* proxy);
368 virtual void onConnectionCreated(
vtkIdType id);
373 virtual void onConnectionClosed(
vtkIdType id);
388 void updateSettingsFromQSettings(
pqServer* server);
391 pqInternal* Internal;
400 model, ((T)0)->staticMetaObject,
reinterpret_cast<QList<void*>*
>(&list), 0);
410 model, ((T)0)->staticMetaObject,
>(&list), server);
418 return qobject_cast<T>(
433 return qobject_cast<T>(
441 return pqFindItems<T>(model).
size();
448 QList<T> items = pqFindItems<T>(model);
449 if (index < items.size())
int pqGetNumberOfItems(const pqServerManagerModel *const model)
QList< T > pqFindItems(const pqServerManagerModel *const model)
vtkSMSession is the default ParaView session.
This is PQ representation for a single representation.
pqServerManagerModelItem is a element maintained by pqServerManagerModel.
T pqGetItemAtIndex(const pqServerManagerModel *const model, int index)
This is a PQ abstraction of a generic view module.
T findItem(const QString &name) const
Returns an item with the given name.
static pqServerManagerModelItem * findItemHelper(const pqServerManagerModel *const model, const QMetaObject &mo, vtkSMProxy *proxy)
Internal method.
T findItem(vtkTypeUInt32 id) const
Given the global id for a proxy, locates a pqServerManagerModelItem subclass for the proxy...
This is a vtkSMProxyManager observer.
QList< T > findItems() const
Returns a list of pqServerManagerModelItem of the given type.
T pqFindItem(const pqServerManagerModel *const model, const QString &name)
T findItem(vtkSMProxy *proxy) const
Given a proxy, locates a pqServerManagerModelItem subclass for the given proxy.
This class represents any registered Server Manager proxy.
pqServerManagerModel is the model for the Server Manager.
int getNumberOfItems() const
Returns the number of items of the given type.
PQ representation for a vtkSMProxy that can be involved in a pipeline.
vtkSession defines a session i.e.
T getItemAtIndex(int index) const
Returns the item of the given type and the given index.
QList< T > findItems(pqServer *server) const
Same as findItems<T>() except that this returns only those items that are on the indicated server...
pqServerResource encapsulates a resource in ParaView.
static void findItemsHelper(const pqServerManagerModel *const model, const QMetaObject &mo, QList< void *> *list, pqServer *server=0)
Internal method.
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
