ParaView client relies of a collection of reactions that autonomous entities that use pqApplicationCore and other core components to get their work done which keeping track for their own enabled state without any external input. More...
| class | pqAboutDialogReaction |
| pqAboutDialogReaction used to show the standard about dialog for the application. More... | |
| class | pqAddToFavoritesReaction |
| Reaction to add selected filter in favorites. More... | |
| class | pqApplicationSettingsReaction |
| pqApplicationSettingsReaction is a reaction to popup the application settings dialog. More... | |
| class | pqAutoApplyReaction |
| Reaction for enabling/disabling auto-apply. More... | |
| class | pqCameraReaction |
| pqCameraReaction has the logic to handle common operations associated with the camera such as reset view along X axis etc. More... | |
| class | pqCameraUndoRedoReaction |
| Reaction for camera undo or redo. More... | |
| class | pqCatalystConnectReaction |
| Reaction for connecting to Catalyst CoProcessing Engine for Live-Data Visualization. More... | |
| class | pqCatalystContinueReaction |
| Reaction for setting a breakpoint to Catalyst CoProcessing Engine for Live-Data Visualization. More... | |
| class | pqCatalystExportReaction |
| Reaction to export a Catalyst script that will produce configured catalyst data products. More... | |
| class | pqCatalystPauseSimulationReaction |
| class | pqCatalystSetBreakpointReaction |
| class | pqChangePipelineInputReaction |
| Reaction for change pipeline input for the currently selected element. More... | |
| class | pqChartSelectionReaction |
| Reaction for creating selections on chart views. More... | |
| class | pqCopyReaction |
| Reaction for copying sources/filters. More... | |
| class | pqDataQueryReaction |
| pqDataQueryReaction is the reaction that popups the Data Query Dialog/Find Data Dialog allowing the user to 'search' his data. More... | |
| class | pqDeleteReaction |
| Reaction for delete sources (all or selected only). More... | |
| class | pqDesktopServicesReaction |
| pqDesktopServicesReaction can be used to open a file (or URL) using QDesktopServices. More... | |
| class | pqEditCameraReaction |
| pqEditCameraReaction is a reaction to show the edit-camera dialog. More... | |
| class | pqEditColorMapReaction |
| Reaction to edit the active representation's color map or solid color. More... | |
| class | pqEditScalarBarReaction |
| Reaction to allow editing of scalar bar properties using a pqProxyWidgetDialog. More... | |
| class | pqExampleVisualizationsDialogReaction |
| pqExampleVisualizationsDialogReaction is used to show the pqExampleVisualizationsDialog when the action is triggered. More... | |
| class | pqExportReaction |
| Reaction for exporting a view. More... | |
| class | pqFiltersMenuReaction |
| Reaction to handle creation of filters from the filters menu. More... | |
| class | pqHelpReaction |
| pqHelpReaction is reaction to show application help using Qt assistant. More... | |
| class | pqIgnoreSourceTimeReaction |
| Reaction for ignoring a source's time information for animations etc. More... | |
| class | pqLinkSelectionReaction |
| class | pqLoadDataReaction |
| Reaction for open data files. More... | |
| class | pqLoadPaletteReaction |
| pqLoadPaletteReaction is used to setup an action that allows the user to load a palette. More... | |
| class | pqLoadRestoreWindowLayoutReaction |
| Reaction to support saving/restoring main window geometry/layout. More... | |
| class | pqLockPanelsReaction |
| Reaction to toggle locking of dockable panels. More... | |
| class | pqLogViewerReaction |
| Reaction for showing the log viewer. More... | |
| class | pqMacroReaction |
| Reaction for creating or deleting a python macro. More... | |
| class | pqMainWindowEventBehavior |
| Reaction to when things are dragged into the main window. More... | |
| class | pqManageCustomFiltersReaction |
| Reaction for showing the custom-filter manager dialog. More... | |
| class | pqManageFavoritesReaction |
| pqManageFavoritesReaction is the reaction to pop-up the favorites manager dialog. More... | |
| class | pqManageLinksReaction |
| pqManageLinksReaction is the reaction to pop-up the links manager dialog. More... | |
| class | pqManagePluginsReaction |
| pqManagePluginsReaction is the reaction to pop-up the plugins manager dialog. More... | |
| class | pqMasterOnlyReaction |
| This is a superclass just to make it easier to collect all such reactions. More... | |
| class | pqReaction |
| class | pqReloadFilesReaction |
| pqReloadFilesReaction adds handler code to reload the active reader. More... | |
| class | pqRenameProxyReaction |
| Reaction for renaming a proxy. More... | |
| class | pqResetScalarRangeReaction |
| Reaction to reset the active lookup table's range to match the active representation. More... | |
| class | pqSaveAnimationGeometryReaction |
| Reaction to save animation geometry. More... | |
| class | pqSaveAnimationReaction |
| Reaction to save animation. More... | |
| class | pqSaveDataReaction |
| Reaction to save data files. More... | |
| class | pqSaveStateReaction |
| Reaction for saving state file. More... | |
| class | pqScalarBarVisibilityReaction |
| Reaction to toggle scalar bar visibility. More... | |
| class | pqSearchItemReaction |
| Reaction to filter item widgets. More... | |
| class | pqSelectionReaction |
| Generric reaction for creating selections on views. More... | |
| class | pqServerConnectReaction |
| Reaction for connecting to a server. More... | |
| class | pqServerDisconnectReaction |
| Reaction to disconnect from a server. More... | |
| class | pqSetMainWindowTitleReaction |
| pqSetMainWindowTitleReaction is the reaction that popups the Set Window Title Dialog allowing the user edit the main window title. More... | |
| class | pqShowHideAllReaction |
| Reaction to show or hide all sources output ports. More... | |
| class | pqSourcesMenuReaction |
| Reaction to handle creation of sources from the sources menu. More... | |
| class | pqTemporalExportReaction |
| Reaction to export a script that will produce configured temporal data products simultaneously. More... | |
| class | pqTestingReaction |
| pqTestingReaction can be used to recording or playing back tests. More... | |
| class | pqTimerLogReaction |
| Reaction for showing the timer log dialog. More... | |
| class | pqToggleInteractionViewMode |
| pqToggleInteractionViewMode is a reaction that toggle 2D/3D interaction mode More... | |
| class | pqTraceReaction |
| Reaction for application python start/stop trace. More... | |
| class | pqUndoRedoReaction |
| Reaction for application undo-redo. More... | |
| class | pqUseSeparateColorMapReaction |
| Reaction to toggle the use of separated color map for an array in a representation. More... | |
| class | pqCatalystRemoveBreakpointReaction |
| class | pqChooseColorPresetReaction |
| Reaction to pop up a color palette chooser dialog. More... | |
| class | pqLoadMaterialsReaction |
| reaction to import an ospray material definition file More... | |
| class | pqResetDefaultSettingsReaction |
| reaction to restore user settings to default. More... | |
| class | pqSaveExtractsReaction |
| reaction to save extracts. More... | |
| class | pqSaveScreenshotReaction |
| Reaction to save a screenshot. More... | |
ParaView client relies on a collection of reactions that are autonomous entities that use pqApplicationCore and other core components to get their work done.
To use, simple create this reaction and assign it to a menu and add it to menus/toolbars whatever.
To use, simply attach an instance of pqReaction subclass to a QAction. The reaction then monitors events from the QAction. Additionally, the reaction can monitor the ParaView application state to update things like enable state, label, etc. for the QAction itself.
