Reaction for creating selections on chart views. More...
#include <pqChartSelectionReaction.h>
| pqChartSelectionReaction (QAction *parent, pqContextView *view, QActionGroup *modifierGroup) | |
| Constructor. More... | |
Public Member Functions inherited from pqSelectionReaction | |
| pqSelectionReaction (QAction *parent, QActionGroup *modifierGroup=NULL) | |
Public Member Functions inherited from pqReaction | |
| pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection) | |
| ~pqReaction () override | |
| QAction * | parentAction () const |
| Provides access to the parent action. More... | |
| static void | startSelection (pqContextView *view, int selectionType, int selectionModifier) |
| start selection on the view where selectionType is one of vtkChart::SELECT_POLYGON, vtkChart::SELECT_RECTANGLE, etc., and selectionModifier is one of vtkContextScene::SELECTION_DEFAULT, vtkContextScene::SELECTION_ADDITION, etc. More... | |
Protected Slots | |
| virtual void | triggered (bool) |
| Called when the action is triggered. More... | |
| void | stopSelection () |
| stops selecting on the view More... | |
| void | modifiersChanged () override |
| called when modifier group is changed. More... | |
| int | getSelectionModifier () override |
Protected Slots inherited from pqSelectionReaction | |
| virtual void | modifiersChanged () |
Protected Slots inherited from pqReaction | |
| virtual void | onTriggered () |
| virtual void | updateEnableState () |
| virtual void | updateMasterEnableState (bool) |
Protected Member Functions inherited from pqSelectionReaction | |
| virtual int | getSelectionModifier () |
| Get the current state of selection modifier, if any. More... | |
| virtual void | uncheckSelectionModifiers () |
| Uncheck selection modifiers, if any. More... | |
| virtual void | disableSelectionModifiers (bool disable) |
| Disable/Enable selection modifiers, if any. More... | |
Protected Attributes inherited from pqSelectionReaction | |
| QPointer< QActionGroup > | ModifierGroup |
Protected Attributes inherited from pqReaction | |
| bool | IsMaster |
Definition at line 45 of file pqChartSelectionReaction.h.
| pqChartSelectionReaction::pqChartSelectionReaction | ( | QAction * | parent, |
| pqContextView * | view, | ||
| QActionGroup * | modifierGroup | ||
Constructor.
parent is expected to have data() that indicates the selection type e.g. vtkChart::SELECT_RECTANGLE or vtkChart::SELECT_POLYGON. QActionGroup modifierGroup is used to determine selection modifier. If there's a non-null checkedAction() in the group, we use that action's data() to determine the selection mode e.g. vtkContextScene::SELECTION_ADDITION, vtkContextScene::SELECTION_SUBTRACTION etc. If no QActionGroup is specified or no checked action is present, then the default mode of vtkContextScene::SELECTION_DEFAULT is used.
protectedvirtualslot |
protectedslot |
overrideprotectedslot |
