Reaction for saving state file.
#include <pqSaveStateReaction.h>
| static bool | saveState () |
| | Open File dialog in order to choose the location and the type of the state file that should be saved Returns true if the user selected a file to save and false if they canceled the dialog. More...
| static bool | saveState (const QString &filename) |
| | Saves the state file. More...
| static bool | savePythonState (const QString &filename) |
| | Saves the state file as a python state. More...
Definition at line 41 of file pqSaveStateReaction.h.
◆ pqSaveStateReaction()
| pqSaveStateReaction::pqSaveStateReaction |
QAction * |
parent | ) |
Constructor.
Parent cannot be NULL.
◆ ~pqSaveStateReaction()
| pqSaveStateReaction::~pqSaveStateReaction |
inlineoverride |
◆ saveState() [1/2]
| static bool pqSaveStateReaction::saveState |
◆ saveState() [2/2]
const QString & |
filename | ) |
Note that this method is static. Applications can simply use this without having to create a reaction instance. Return true if the operation succeeded otherwise return false.
◆ savePythonState()
| static bool pqSaveStateReaction::savePythonState |
const QString & |
filename | ) |
◆ updateEnableState
| void pqSaveStateReaction::updateEnableState |
overrideslot |
Updates the enabled state.
◆ onTriggered()
| void pqSaveStateReaction::onTriggered |
inlineoverrideprotectedvirtual |
