Reaction to allow editing of scalar bar properties using a pqProxyWidgetDialog.
#include <pqEditScalarBarReaction.h>
Reaction allows editing of scalar bar properties using a pqProxyWidgetDialog. Internally, it uses pqScalarBarVisibilityReaction to track the visibility state for the scalar to enable/disable the parent action.
Definition at line 51 of file pqEditScalarBarReaction.h.
◆ pqEditScalarBarReaction()
| pqEditScalarBarReaction::pqEditScalarBarReaction |
QAction * |
parent = 0, |
bool |
track_active_objects = true |
◆ ~pqEditScalarBarReaction()
| pqEditScalarBarReaction::~pqEditScalarBarReaction |
◆ setRepresentation
Set the active representation.
This should only be used when track_active_objects is false. If used when track_active_objects is true, the representation will get replaced whenever the active representation changes.
◆ editScalarBar
| bool pqEditScalarBarReaction::editScalarBar |
slot |
Show the editor dialog for editing scalar bar properties.
◆ updateEnableState
| void pqEditScalarBarReaction::updateEnableState |
overrideprotectedslot |
Updates the enabled state.
◆ onTriggered
| void pqEditScalarBarReaction::onTriggered |
Called when the action is triggered.
