Reaction to reset the active lookup table's range to match the active representation.
#include <pqResetScalarRangeReaction.h>
You can disable tracking of the active representation, instead explicitly provide one using setRepresentation() by pass track_active_objects as false to the constructor.
Definition at line 53 of file pqResetScalarRangeReaction.h.
◆ Modes
◆ pqResetScalarRangeReaction()
| pqResetScalarRangeReaction::pqResetScalarRangeReaction |
QAction * |
parent, |
bool |
track_active_objects = true, |
Modes |
mode = DATA |
if track_active_objects is false, then the reaction will not track pqActiveObjects automatically.
◆ ~pqResetScalarRangeReaction()
| pqResetScalarRangeReaction::~pqResetScalarRangeReaction |
◆ resetScalarRange()
◆ resetScalarRangeToData()
Reset to current data range.
- Parameters
| [in] | repr | The data representation to use to determine the data range. If nullptr, then the active representation is used, if available. |
- Returns
true if the operation was successful, otherwise false.
◆ resetScalarRangeToCustom() [1/2]
Reset range to a custom range.
- Parameters
| [in] | repr | The representation used to determine the transfer function to change range on. If repr is nullptr, then the active representation is used, if available. |
- Returns
◆ resetScalarRangeToCustom() [2/2]
| static bool pqResetScalarRangeReaction::resetScalarRangeToCustom |
vtkSMProxy * |
tfProxy, |
bool |
separateOpacity = false |
- Parameters
| [in] | tfProxy | The transfer function proxy to reset the range on. |
| [in] | separateOpacity | Show controls for setting the opacity function range separately from the color transfer function. |
- Returns
◆ resetScalarRangeToDataOverTime()
Reset range to data range over time.
- Parameters
- Returns
◆ resetScalarRangeToVisible()
Reset range to data range for data visible in the view.
- Parameters
- Returns
◆ updateEnableState
| void pqResetScalarRangeReaction::updateEnableState |
overrideslot |
Updates the enabled state.
◆ setRepresentation
Set the data representation explicitly when track_active_objects is false.
◆ onTriggered()
| void pqResetScalarRangeReaction::onTriggered |
overrideprotectedvirtual |
Called when the action is triggered.
◆ onServerAdded
| virtual void pqResetScalarRangeReaction::onServerAdded |
pqServer * |
server | ) |
protectedvirtualslot |
◆ onAboutToRemoveServer
| virtual void pqResetScalarRangeReaction::onAboutToRemoveServer |
pqServer * |
server | ) |
