Reaction to disconnect from a server.
#include <pqServerDisconnectReaction.h>
Definition at line 42 of file pqServerDisconnectReaction.h.
◆ pqServerDisconnectReaction()
| pqServerDisconnectReaction::pqServerDisconnectReaction |
QAction * |
parent | ) |
Constructor.
Parent cannot be NULL.
◆ disconnectFromServer()
| static void pqServerDisconnectReaction::disconnectFromServer |
Disconnects from active server.
Note that this method is static. Applications can simply use this without having to create a reaction instance.
◆ disconnectFromServerWithWarning()
| static bool pqServerDisconnectReaction::disconnectFromServerWithWarning |
Disconnects from active server with a warning message to the user to confirm that active proxies will be destroyed, if any.
Returns true if disconnect happened, false if not i.e. the user cancelled the operation.
◆ onTriggered()
| void pqServerDisconnectReaction::onTriggered |
overrideprotectedvirtual |
Called when the action is triggered.
◆ UpdateTimer
| pqTimer pqServerDisconnectReaction::UpdateTimer |
