| virtual void | SetOutputDataType (int) |
| | Controls the output type. More...
| virtual int | GetOutputDataType () |
| virtual void | SetWholeExtent (int, int, int, int, int, int) |
| | Controls the output WHOLE_EXTENT. More...
| virtual void | SetWholeExtent (int [6]) |
| virtual int * | GetWholeExtent () |
| virtual void | GetWholeExtent (int &, int &, int &, int &, int &, int &) |
| virtual void | GetWholeExtent (int [6]) |
| virtual void | SetProcessType (int) |
| | Optionally, set the process type. More...
| virtual int | GetProcessType () |
| void | SetController (vtkMultiProcessController *) |
| | Get/Set the controller to use. More...
| virtual vtkMultiProcessController * | GetController () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkClientServerMoveData () |
| | ~vtkClientServerMoveData () override |
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| virtual int | SendData (vtkDataObject *, vtkMultiProcessController *) |
| virtual vtkDataObject * | ReceiveData (vtkMultiProcessController *) |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Moves data from the server root node to the client.
This class moves all the input data available at the input on the root server node to the client node. If not in server-client mode, this filter behaves as a simple pass-through filter. This can work with any data type, the application does not need to set the output type before hand.
- Warning
- This filter may change the output in RequestData().
Definition at line 38 of file vtkClientServerMoveData.h.
