| | Overridden to update state of GenerateCellConnectivity and FieldAssociation which is specified on the view. More...
| | Since this has no delivery, just mark ourselves modified. More...
| vtkAlgorithmOutput * | GetDataProducer () |
| vtkAlgorithmOutput * | GetExtractedDataProducer () |
| vtkAlgorithmOutput * | GetSelectionProducer () |
| void | AddCompositeDataSetIndex (unsigned int index) |
| | Select the block indices to extract. More...
| void | RemoveAllCompositeDataSetIndices () |
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| virtual void | SetVisibility (bool val) |
| | Get/Set the visibility for this representation. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkSpreadSheetRepresentation () |
| | ~vtkSpreadSheetRepresentation () override |
| void | SetGenerateCellConnectivity (bool) |
| | This is called in ProcessViewRequest during the vtkPVView::REQUEST_UPDATE pass. More...
| void | SetFieldAssociation (int val) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
