| | Only one input which is the table to sort. More...
| const char * | GetColumnNameToSort () |
| | Choose on which column the sort operation should occur. More...
| void | SetColumnNameToSort (const char *columnName) |
| void | SetInvertOrder (int newValue) |
| virtual int | GetInvertOrder () |
| virtual vtkIdType | GetBlock () |
| | Block index used to select a data range. More...
| virtual void | SetBlock (vtkIdType) |
| virtual vtkIdType | GetBlockSize () |
| | Set the block size. More...
| virtual void | SetBlockSize (vtkIdType) |
| virtual int | GetSelectedComponent () |
| virtual void | SetSelectedComponent (int) |
| void | SetController (vtkMultiProcessController *) |
| | Get/Set the MPI controller used for gathering. More...
| virtual vtkMultiProcessController * | GetController () |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkSortedTableStreamer () |
| | ~vtkSortedTableStreamer () override |
| void | CreateInternalIfNeeded (vtkTable *input, vtkDataArray *data) |
| vtkDataArray * | GetDataArrayToProcess (vtkTable *input) |
| virtual char * | GetColumnToSort () |
| virtual void | SetColumnToSort (const char *) |
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
return a sorted subset of the original table
This filter is used quickly get a sorted subset of a given vtkTable. By sorted we mean a subset build from a global sort even if some optimisation allow us to skip a global table sorting.
Definition at line 41 of file vtkSortedTableStreamer.h.
