| virtual vtkIdType | GetNumberOfElements () |
| | Returns the number of elements for the value type. More...
| bool | IsValueDefault () override |
| | Returns true if the current value is the same as the default value. More...
| void | Copy (vtkSMProperty *src) override |
| | Copy all property values. More...
| int | IsInDomains () |
| | Returns true if all values are in all domains, false otherwise. More...
| int | IsInDomains (vtkSMDomain **domain) |
| | Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
| void | UnRegister (vtkObjectBase *obj) override |
| | Overloaded to break the reference loop caused by the internal domain iterator. More...
| vtkSMDomainIterator * | NewDomainIterator () |
| | Creates, initializes and returns a new domain iterator. More...
| vtkSMDomain * | GetDomain (const char *name) |
| | Returns a domain give a name. More...
| vtkSMDomain * | FindDomain (const char *classname) |
| | Returns the first domain which is of the specified type. More...
| template<class DomainType > |
| DomainType * | FindDomain () |
| | Same as FindDomain(classname), except the classname is deduced from the type. More...
| unsigned int | GetNumberOfDomains () |
| | Returns the number of domains this property has. More...
| void | AddDomain (const char *name, vtkSMDomain *dom) |
| | Properties can have one or more domains. More...
| virtual void | AddLinkedProperty (vtkSMProperty *targetProperty) |
| | Add a link to a property whose value should be synchronized with this property value. More...
| virtual void | RemoveLinkedProperty (vtkSMProperty *targetProperty) |
| | Remove a link to a property added with AddLinkedProperty() More...
| virtual void | RemoveFromSourceLink () |
| | Remove a link from the source property. More...
| void | ResetToDefault () |
| | Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
| virtual void | ResetToXMLDefaults () |
| | For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
| virtual bool | ResetToDomainDefaults (bool use_unchecked_values=false) |
| | Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
| vtkSMProxy * | GetParent () |
| | Get the proxy to which this property belongs. More...
| virtual bool | IsStateIgnored () |
| bool | HasDomainsWithRequiredProperties () |
| | Returns true if the property has a domain with required properties. More...
| virtual void | ClearUncheckedElements () |
| | Use this method to clear unchecked values set of this property. More...
| | The command name used to set the value on the server object. More...
| virtual void | SetImmediateUpdate (int) |
| | If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
| virtual int | GetImmediateUpdate () |
| virtual int | GetInformationOnly () |
| | Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
| virtual int | GetIgnoreSynchronization () |
| | If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
| virtual vtkSMProperty * | GetInformationProperty () |
| | Get the associated information property. More...
| virtual void | SetAnimateable (int) |
| | Get/Set if the property is animateable. More...
| virtual int | GetAnimateable () |
| virtual void | SetIsInternal (int) |
| | Get/Set if the property is internal to server manager. More...
| virtual int | GetIsInternal () |
| virtual void | SetNoCustomDefault (int) |
| | Sets whether the property should ignore custom default settings. More...
| virtual int | GetNoCustomDefault () |
| | Gets whether the property should ignore custom default settings. More...
| virtual void | SetPanelVisibility (const char *) |
| | Sets the panel visibility for the property. More...
| virtual char * | GetPanelVisibility () |
| | Returns the panel visibility for the property. More...
| virtual void | SetPanelVisibilityDefaultForRepresentation (const char *) |
| | Sets the panel visibility to default if the current representation type matches representation. More...
| virtual char * | GetPanelVisibilityDefaultForRepresentation () |
| | Returns which representation type the property will be shown by default for. More...
| virtual void | SetPanelWidget (const char *) |
| | Sets the name of the custom panel widget to use for the property. More...
| virtual char * | GetPanelWidget () |
| | Returns name of the panel widget for the property. More...
| virtual void | SetDisableSubTrace (const char *) |
| | Sets the tracing of sub property of this property. More...
| virtual char * | GetDisableSubTrace () |
| | Returns the tracing state of the properties of this property. More...
| | The label assigned by the xml parser. More...
| | The name assigned by the xml parser. More...
| virtual int | GetRepeatable () |
| | If repeatable, a property can have 1 or more values of the same kind. More...
| | The server manager configuration XML may define <Hints/> element for a property. More...
| void | Modified () override |
| | Overridden to support blocking of modified events. More...
| | vtkSMMapProperty () |
| | ~vtkSMMapProperty () override |
| int | LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override |
| | Updates state from an XML element. More...
| int | ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override |
| | vtkSMProperty () |
| | ~vtkSMProperty () override |
| virtual void | WriteTo (vtkSMMessage *msg) |
| | Let the property write its content into the stream. More...
| virtual void | ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *) |
| | Let the property read and set its content from the stream. More...
| virtual void | UpdateAllInputs () |
| | Update all proxies referred by this property (if any). More...
| | Internal. More...
| void | AddDependent (vtkSMDomain *dom) |
| | Internal. More...
| void | RemoveAllDependents () |
| | Removes all dependents. More...
| void | UpdateDomains () |
| | Calls Update() on all domains contained by the property as well as all dependent domains. More...
| virtual void | SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1) |
| | Save the property state in XML. More...
| virtual void | SaveStateValues (vtkPVXMLElement *propertyElement) |
| | This method must be overridden by concrete class in order to save the real property data. More...
| virtual void | SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid) |
| | Save property domain. More...
| virtual void | SetInformationOnly (int) |
| virtual void | SetIgnoreSynchronization (int) |
| void | SetInformationProperty (vtkSMProperty *ip) |
| void | SetDocumentation (vtkSMDocumentation *) |
| void | SetParent (vtkSMProxy *proxy) |
| virtual void | SetStateIgnored (bool) |
| virtual void | StateIgnoredOn () |
| virtual void | StateIgnoredOff () |
| bool | SetBlockModifiedEvents (bool block) |
| | Block/unblock modified events, returns the current state of the block flag. More...
| virtual bool | GetPendingModifiedEvents () |
| | Returns if any modified evetns are pending. More...
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
abstract superclass for all map properties
vtkSMMapProperty defines an interface common for all map properties. A map property stores a set of keys and values.
Definition at line 29 of file vtkSMMapProperty.h.
