int range domain based on the number of components available in a particular data array.
| void | Update (vtkSMProperty *prop) override |
| | Updates the range based on the scalar range of the currently selected array. More...
Public Member Functions inherited from vtkSMEnumerationDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (int val, unsigned int &idx) |
| | Returns true if the int is in the domain. More...
| unsigned int | GetNumberOfEntries () |
| | Returns the number of entries in the enumeration. More...
| int | GetEntryValue (unsigned int idx) |
| | Returns the integer value of an enumeration entry. More...
| const char * | GetEntryText (unsigned int idx) |
| | Returns the descriptive string of an enumeration entry. More...
| const char * | GetEntryTextForValue (int value) |
| | Returns the text for an enumeration value. More...
| int | HasEntryText (const char *text) |
| | Return 1 is the text is present in the enumeration, otherwise 0. More...
| int | GetEntryValueForText (const char *text) |
| | Get the value for an enumeration text. More...
| int | GetEntryValue (const char *text, int &valid) |
| | Given an entry text, return the integer value. More...
| const char * | GetInfoText (unsigned int idx) |
| | Returns the info text for an enumeration entry. More...
| void | AddEntry (const char *text, int value, const char *info=nullptr) |
| | Add a new enumeration entry. More...
| void | RemoveAllEntries () |
| | Clear all entries. More...
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMNumberOfComponentsDomain () |
| | ~vtkSMNumberOfComponentsDomain () override |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | Update (const char *arrayname, vtkSMSourceProxy *sp, vtkSMInputArrayDomain *iad, int outputport) |
| | Internal update method doing the actual work. More...
Protected Member Functions inherited from vtkSMEnumerationDomain |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| | vtkSMEnumerationDomain () |
| | ~vtkSMEnumerationDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
vtkSMNumberOfComponentsDomain is used for properties that allow the user to choose the component number (or associated name) to process for the chosen array. It needs two required properties with following functions:
- Input – input property for the filter.
- ArraySelection – string vector property used to select the array. This domain will not work if either of the required properties is missing.
Definition at line 37 of file vtkSMNumberOfComponentsDomain.h.
