| | Update self checking the "unchecked" values of all required properties. More...
| void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
Public Member Functions inherited from vtkSMIntRangeDomain |
| int | GetMinimum (unsigned int idx, int &exists) |
| | Return a min. More...
| int | GetMaximum (unsigned int idx, int &exists) |
| | Return a max. More...
| int | GetMinimumExists (unsigned int idx) |
| | Returns if minimum/maximum bound is set for the domain. More...
| int | GetMaximumExists (unsigned int idx) |
| int | GetMinimum (unsigned int idx) |
| | Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
| int | GetMaximum (unsigned int idx) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| void | Update (vtkSMProxyProperty *pp) |
Protected Member Functions inherited from vtkSMIntRangeDomain |
| | vtkSMIntRangeDomain () |
| | ~vtkSMIntRangeDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | vtkSMExtentDomain () |
| | ~vtkSMExtentDomain () override |
int range domain based on data set extent
vtkSMExtentDomain is a subclass of vtkSMIntRangeDomain. In its Update method, it determines the minimum and maximum extent in each dimension of the structured data set with which it is associated. It requires a vtkSMSourceProxy to do this.
- See also
- vtkSMIntRangeDomain
Definition at line 35 of file vtkSMExtentDomain.h.
