| | Overridden to setup domain range values based on required properties supported by this domain. More...
Public Member Functions inherited from vtkSMIntRangeDomain |
| int | GetMinimum (unsigned int idx, int &exists) |
| | Return a min. More...
| int | GetMaximum (unsigned int idx, int &exists) |
| | Return a max. More...
| int | GetMinimumExists (unsigned int idx) |
| | Returns if minimum/maximum bound is set for the domain. More...
| int | GetMaximumExists (unsigned int idx) |
| int | GetMinimum (unsigned int idx) |
| | Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
| int | GetMaximum (unsigned int idx) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMAnimationFrameWindowDomain () |
| | ~vtkSMAnimationFrameWindowDomain () override |
Protected Member Functions inherited from vtkSMIntRangeDomain |
| | vtkSMIntRangeDomain () |
| | ~vtkSMIntRangeDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
domain for animation frame window.
vtkSMAnimationFrameWindowDomain is used on the "FrameWindow" property on the "SaveAnimation" proxy. It's a int-range, where the range is determined using the animation scene's play mode and frame rate.
Definition at line 30 of file vtkSMAnimationFrameWindowDomain.h.
