| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the propertyy is in the domain. More...
| bool | IsInDomain (unsigned int idx, T val) |
| | Returns true if the double (val) is in the domain. More...
| T | GetMinimum (unsigned int idx, int &exists) |
| | Return a min. More...
| T | GetMaximum (unsigned int idx, int &exists) |
| | Return a max. More...
| int | GetResolution () |
| | Returns a resolution. More...
| bool | GetResolutionExists () |
| | Returns if a resolution is set for the domain. More...
| T | GetMinimum (unsigned int idx) |
| | Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
| T | GetMaximum (unsigned int idx) |
| unsigned int | GetNumberOfEntries () |
| | Returns the number of entries in the internal maxima/minima list. More...
| | Update self checking the "unchecked" values of all required properties. More...
| void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
| DefaultModes | GetDefaultMode (unsigned int index=0) |
| | Get the default-mode that controls how SetDefaultValues() behaves. More...
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Set the property's default value based on the domain. More...
| bool | GetMinimumExists (unsigned int idx) |
| | Returns if minimum/maximum bound is set for the domain. More...
| bool | GetMaximumExists (unsigned int idx) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMRangeDomainTemplate () |
| | ~vtkSMRangeDomainTemplate () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| const std::vector< vtkEntry > & | GetEntries () const |
| void | SetEntries (const std::vector< vtkEntry > &new_value) |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
template<class T>
class vtkSMRangeDomainTemplate< T >
superclass for type-specific range domains i.e.
domains that constrain a value within a min and max.
vtkSMRangeDomainTemplate represents an interval in real space (using precision based on the data-type) specified using a min and a max value. Valid XML attributes are:
* * min
* * max
* * resolution
Both min and max attributes can have one or more space space separated value arguments. Resolution expects only one value. Optionally, a Required Property may be specified (which typically is a information property) which can be used to obtain the range for the values as follows:
* <DoubleRangeDomain ...>
* <RequiredProperties>
* <Property name="<InfoPropName>" function="RangeInfo" />
* </RequiredProperties>
* </DoubleRangeDomain>
vtkSMRangeDomainTemplate provides a mechanism to control how the default value for any property can be determined using the domain either the min, max or mid of the range. One can do that using the "default_mode" attribute in XML with valid values as "min", "max", "mid", or a comma separated sequence of the three e.g "min,max,min". If none is specified, "mid" is assumed. The comma-separated sequence can be used to set a different mode for each component of the property i.e. "min,max,min" means set element 0 as min, element 1 as max and element 2 and min. If the number of elements on the property is less than the number of default specified, the last value is assumed to be repeated. Thus, "min,max,min" is same as the regular expression "min,max,min(,min)*".
Definition at line 64 of file vtkSMRangeDomainTemplate.h.
