| void | Update (vtkSMProperty *prop) override |
| | Updates the range based on the scalar range of the currently selected array. More...
Public Member Functions inherited from vtkSMDoubleRangeDomain |
| double | GetMinimum (unsigned int idx, int &exists) |
| | Return a min. More...
| double | GetMaximum (unsigned int idx, int &exists) |
| | Return a max. More...
| int | GetMinimumExists (unsigned int idx) |
| | Returns if minimum/maximum bound is set for the domain. More...
| int | GetMaximumExists (unsigned int idx) |
| double | GetMinimum (unsigned int idx) |
| | Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
| double | GetMaximum (unsigned int idx) |
| int | GetResolution () |
| | Returns the resolution. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMArrayRangeDomain () |
| | ~vtkSMArrayRangeDomain () override |
| void | Update (const char *arrayName, int fieldAssociation, vtkSMSourceProxy *producer, int producerPort, int component=-1) |
Protected Member Functions inherited from vtkSMDoubleRangeDomain |
| | vtkSMDoubleRangeDomain () |
| | ~vtkSMDoubleRangeDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
double range domain based on array range
vtkSMArrayRangeDomain is a sub-class of vtkSMDoubleRangeDomain. In it's Update(), it sets min/max values based on the range of an input array. It requires Input (vtkSMProxyProperty) and ArraySelection (vtkSMStringVectorProperty) properties.
- See also
- vtkSMDoubleRangeDomain vtkSMProxyProperty vtkSMStringVectorProperty
Definition at line 35 of file vtkSMArrayRangeDomain.h.
