| | Update self checking the "unchecked" values of all required properties. More...
| virtual double | GetScaleFactor () |
| virtual int | GetAxisFlags () |
| int | SetDefaultValues (vtkSMProperty *property, bool use_unchecked_values) override |
| | Overridden to handle APPROXIMATE_CELL_LENGTH. More...
| virtual void | SetMode (int) |
| virtual int | GetMode () |
Public Member Functions inherited from vtkSMDoubleRangeDomain |
| double | GetMinimum (unsigned int idx, int &exists) |
| | Return a min. More...
| double | GetMaximum (unsigned int idx, int &exists) |
| | Return a max. More...
| int | GetMinimumExists (unsigned int idx) |
| | Returns if minimum/maximum bound is set for the domain. More...
| int | GetMaximumExists (unsigned int idx) |
| double | GetMinimum (unsigned int idx) |
| | Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
| double | GetMaximum (unsigned int idx) |
| int | GetResolution () |
| | Returns the resolution. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMBoundsDomain () |
| | ~vtkSMBoundsDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| vtkPVDataInformation * | GetInputInformation () |
| vtkSMIntVectorProperty * | GetAxisFlagsInformation () |
| bool | IsAxisEnabled (int axis) |
| void | SetDomainValues (double bounds[6]) |
| void | UpdateOriented () |
Protected Member Functions inherited from vtkSMDoubleRangeDomain |
| | vtkSMDoubleRangeDomain () |
| | ~vtkSMDoubleRangeDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
double range domain based on data set bounds
vtkSMBoundsDomain extends vtkSMDoubleRangeDomain to add support to determine the valid range for the values based on the dataset bounds. There are several Modes which can be used to control how the range is computed based on the data bounds (defined by the vtkSMBoundsDomain::Modes enum).
NORMAL : this is the basic mode where the domain will have 3 ranges which are the min and max for the bounds along each of the coordinate axis.
MAGNITUDE: the domain has a single range set to (-magn/2.0, +magn/2.0) where magn is the magnitude of the diagonal.
ORIENTED_MAGNITUDE: same as MAGNITUDE, but instead of the diagonal, a vector determined using two additional required properties with functions Normal, and Origin is used.
COMPONENT_MAGNITUDE: similar to MAGNITUDE except suitable for 3 component properties where each component is given range for the corresponding axis i.e. (0, xmax-xmin), (0, ymax-ymin), (0, zmax-zmin).
SCALED_EXTENT: the range is set to (0, maxbounds * this->ScaleFactor) where maxbounds is the length of the longest axis for the bounding box.
ARRAY_SCALED_EXTENT: the range is set to (0, (arrayMagnitude / maxbounds) * this->ScaleFactor) where maxbounds is the length of the longest axis for the bounding box. and arrayMagnitude the maximum magnitude of the array.
APPROXIMATE_CELL_LENGTH: approximation for cell length computed using the
DATA_BOUNDS: this mode for a 6 tuple property that takes the data bounds. The range will have 6 ranges: (xmin,xmax), (xmin,xmax), (ymin,ymax), (ymin,ymax), (zmin,zmax), and (zmin,zmax). If default_mode is not specified, then "min,max,min,max,min,max" is assumed.
EXTENTS: this mode for a property that takes a value between 0 and (max-min) for each component.
To determine the input data bounds, this domain depends on a required property with function Input. The data-information from the source-proxy set as the value for that property is used to determine the bounds.
Supported XML attributes:
mode : used to specify the Mode. Value can be "normal", "magnitude", "oriented_magnitude", "scaled_extent", "array_scaled_extent", or "approximate_cell_length", "data_bounds".
scale_factor : used in SCALED_EXTENT, ARRAY_SCALED_EXTENT and APPROXIMATE_CELL_LENGTH mode. Value is a floating point number that is used as the scale factor.
Definition at line 71 of file vtkSMBoundsDomain.h.
