| void | SetSelectionRepresentation (vtkChartSelectionRepresentation *) |
| | These must only be set during initialization before adding the representation to any views or calling Update(). More...
| void | SetVisibility (bool visible) override |
| | Set visibility of the representation. More...
| | This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
| void | SetCompositeDataSetIndex (unsigned int) |
| void | AddCompositeDataSetIndex (unsigned int) |
| void | ResetCompositeDataSetIndices () |
| unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
| | Override because of internal selection representations that need to be initialized as well. More...
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| virtual std::string | GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) |
| | Method to provide the default name given the name of a table and a column in that table. More...
| virtual bool | MapSelectionToInput (vtkSelection *sel) |
| | This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
| virtual bool | MapSelectionToView (vtkSelection *sel) |
| | This is the inverse of MapSelectionToInput(). More...
| virtual bool | Export (vtkCSVExporter *vtkNotUsed(exporter)) |
| | Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
| void | SetFieldAssociation (int) |
| | Set the field association for arrays to use. More...
| virtual int | GetFieldAssociation () |
| virtual void | SetFlattenTable (int) |
| | Flatten the table, i.e. More...
| virtual int | GetFlattenTable () |
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkChartRepresentation () |
| | ~vtkChartRepresentation () override |
| virtual void | PrepareForRendering () |
| | This method is called before actual render if this->MTime was modified since the last time this method was called. More...
| | Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| vtkTable * | GetLocalOutput (bool pre_delivery=false) |
| | Convenience method to get the first vtkTable from LocalOutput, if any. More...
| virtual vtkSmartPointer< vtkDataObject > | TransformInputData (vtkDataObject *data) |
| | Method to be overridden to transform input data. More...
| virtual vtkSmartPointer< vtkDataObject > | ReduceDataToRoot (vtkDataObject *data) |
| | Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
| virtual vtkSmartPointer< vtkDataObject > | TransformTable (vtkSmartPointer< vtkDataObject > table) |
| | Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
| bool | GetLocalOutput (MapOfTables &tables) |
| | Convenience method to get all vtkTable instances with their associated names. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
