vtkPVContextView adopts vtkContextView so that it can be used in ParaView configurations. More...
#include <vtkPVContextView.h>
| typedef vtkPVView | Superclass |
Public Types inherited from vtkPVView | |
| typedef vtkView | Superclass |
Public Types inherited from vtkView | |
| void | StillRender () override |
| Triggers a high-resolution render. More... | |
| void | InteractiveRender () override |
| Triggers a interactive render. More... | |
| virtual vtkAbstractContextItem * | GetContextItem ()=0 |
| Get the context item. More... | |
| virtual void | SetSelection (vtkChartRepresentation *repr, vtkSelection *selection)=0 |
| Representations can use this method to set the selection for a particular representation. More... | |
| vtkSelection * | GetSelection () |
| Get the current selection created in the view. More... | |
| virtual bool | Export (vtkCSVExporter *exporter) |
| Export the contents of this view using the exporter. More... | |
| virtual vtkContextView * | GetContextView () |
| Get the context view. More... | |
| virtual void | SetupInteractor (vtkRenderWindowInteractor *) |
| Set the interactor. More... | |
| vtkRenderWindowInteractor * | GetInteractor () |
| virtual void | SetTitle (const char *) |
| Get/Set the title. More... | |
| virtual char * | GetTitle () |
| virtual void | SetTitleFont (const char *family, int pointSize, bool bold, bool italic)=0 |
| Get/Set the font of the title. More... | |
| virtual void | SetTitleFontFamily (const char *family)=0 |
| virtual void | SetTitleFontSize (int pointSize)=0 |
| virtual void | SetTitleBold (bool bold)=0 |
| virtual void | SetTitleItalic (bool italic)=0 |
| virtual void | SetTitleFontFile (const char *file)=0 |
| virtual const char * | GetTitleFontFamily ()=0 |
| virtual int | GetTitleFontSize ()=0 |
| virtual int | GetTitleFontBold ()=0 |
| virtual int | GetTitleFontItalic ()=0 |
| virtual void | SetTitleColor (double red, double green, double blue)=0 |
| Get/Set the color of the title. More... | |
| virtual double * | GetTitleColor ()=0 |
Public Member Functions inherited from vtkPVView | |
| virtual void | SetPPI (int) |
| Description: Set the screen PPI. More... | |
| virtual int | GetPPI () |
| void | Update () override |
| Overridden to not call Update() directly on the input representations, instead use ProcessViewRequest() for all vtkPVDataRepresentations. More... | |
| bool | InTileDisplayMode () |
| Returns true if the application is currently in tile display mode. More... | |
| bool | InCaveDisplayMode () |
| Returns true if the application is currently in cave/immersive display mode. More... | |
| bool | GetLocalProcessSupportsInteraction () |
| Returns true if the local process can support interaction. More... | |
| vtkRenderWindow * | GetRenderWindow () |
| If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More... | |
| virtual void | ScaleRendererViewports (const double viewport[4]) |
| vtkViewLayout calls this method to update the total viewport available for this view. More... | |
| vtkMTimeType | GetUpdateTimeStamp () |
| Provides access to the time when Update() was last called. More... | |
| virtual void | Deliver (int use_lod, unsigned int size, unsigned int *representation_ids) |
| Called on all processes to request data-delivery for the list of representations. More... | |
| virtual bool | IsCached (vtkPVDataRepresentation *) |
Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More... | |
| virtual void | ClearCache (vtkPVDataRepresentation *) |
Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More... | |
| virtual void | SetPosition (int, int) |
| Set the position on this view in the multiview configuration. More... | |
| virtual int * | GetPosition () |
| virtual void | GetPosition (int &, int &) |
| virtual void | GetPosition (int [2]) |
| virtual void | SetSize (int, int) |
| Set the size of this view in the multiview configuration. More... | |
| virtual int * | GetSize () |
| virtual void | GetSize (int &, int &) |
| virtual void | GetSize (int [2]) |
| virtual void | SetViewTime (double value) |
| Get/Set the time this view is showing. More... | |
| virtual double | GetViewTime () |
| virtual void | SetCacheKey (double) |
| Get/Set the cache key. More... | |
| virtual double | GetCacheKey () |
| virtual void | SetUseCache (bool) |
| Get/Set whether caching is enabled. More... | |
| virtual bool | GetUseCache () |
| virtual void | PrepareForScreenshot () |
| These methods are used to setup the view for capturing screen shots. More... | |
| virtual void | CleanupAfterScreenshot () |
| void | SetTileScale (int x, int y) |
| When saving screenshots with tiling, these methods get called. More... | |
| void | SetTileViewport (double x0, double y0, double x1, double y1) |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| void | SetDeliveryManager (vtkPVDataDeliveryManager *) |
| Provides access to data delivery & cache manager for this view. More... | |
| virtual vtkPVDataDeliveryManager * | GetDeliveryManager () |
Public Member Functions inherited from vtkView | |
| vtkView * | NewInstance () const |
| void | AddRepresentation (vtkDataRepresentation *rep) |
| void | SetRepresentation (vtkDataRepresentation *rep) |
| vtkDataRepresentation * | AddRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | SetRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | AddRepresentationFromInput (vtkDataObject *input) |
| vtkDataRepresentation * | SetRepresentationFromInput (vtkDataObject *input) |
| void | RemoveRepresentation (vtkDataRepresentation *rep) |
| void | RemoveRepresentation (vtkAlgorithmOutput *rep) |
| void | RemoveAllRepresentations () |
| int | GetNumberOfRepresentations () |
| vtkDataRepresentation * | GetRepresentation (int index=0) |
| bool | IsRepresentationPresent (vtkDataRepresentation *rep) |
| vtkCommand * | GetObserver () |
| void | RegisterProgress (vtkObject *algorithm, const char *message=NULL) |
| void | UnRegisterProgress (vtkObject *algorithm) |
| static vtkPVContextView * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVView | |
| static vtkPVView * | SafeDownCast (vtkObject *o) |
| static void | SetEnableStreaming (bool) |
| static bool | GetEnableStreaming () |
| static vtkInformationObjectBaseKey * | VIEW () |
| Key used to pass the vtkPVView pointer to the representation during any of the view passes such as REQUEST_UPDATE(), REQUEST_UPDATE_LOD(), REQUEST_RENDER(), etc. More... | |
| static vtkInformationRequestKey * | REQUEST_UPDATE () |
| This is a Update-Data pass. More... | |
| static vtkInformationRequestKey * | REQUEST_UPDATE_LOD () |
| This is a Update-LOD-Data pass. More... | |
| static vtkInformationRequestKey * | REQUEST_RENDER () |
| This is a render pass. More... | |
| static void | SetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0) |
| static vtkDataObject * | GetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static vtkDataObject * | GetDeliveredPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0) |
| static vtkDataObject * | GetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static vtkDataObject * | GetDeliveredPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetUseGenericOpenGLRenderWindow (bool val) |
| Use this to indicate that the process should use vtkGenericOpenGLRenderWindow rather than vtkRenderWindow when creating an new render window. More... | |
| static bool | GetUseGenericOpenGLRenderWindow () |
Static Public Member Functions inherited from vtkView | |
| static vtkView * | New () |
| static vtkView * | SafeDownCast (vtkObjectBase *o) |
| vtkContextView * | ContextView |
| Get/Set the alignement of the title. More... | |
| virtual void | SetTitleAlignment (int alignment)=0 |
| virtual int | GetTitleAlignment ()=0 |
| vtkPVContextView () | |
| ~vtkPVContextView () override | |
| virtual void | Render (bool interactive) |
| Actual rendering implementation. More... | |
| virtual bool | MapSelectionToInput (vtkSelection *) |
| Called to transform the selection. More... | |
| virtual std::string | GetFormattedTitle () |
| Method to get the Formatted title after replacing some key strings eg: ${TIME} Child class should inherit this to add their own key strings. More... | |
Protected Member Functions inherited from vtkPVView | |
| vtkPVView (bool create_render_window=true) | |
| ~vtkPVView () override | |
| vtkRenderWindow * | NewRenderWindow () |
| Subclasses should use this method to create new render windows instead of directly creating a new one. More... | |
| void | SetRenderWindow (vtkRenderWindow *) |
| Subclasses can use this method to set the render window created for this view. More... | |
| void | AllReduce (const vtkBoundingBox &source, vtkBoundingBox &dest) |
| Reduce bounding box between all participating processes. More... | |
| void | AllReduce (const vtkTypeUInt64 source, vtkTypeUInt64 &dest, int operation, bool skip_data_server=false) |
| Reduce between all participating processes using the operation (vtkCommunicator::StandardOperations) specified. More... | |
| vtkPVSession * | GetSession () |
| virtual bool | GetInCaptureScreenshot () |
Flag set to true between calls to PrepareForScreenshot and CleanupAfterScreenshot. More... | |
| void | AddRepresentationInternal (vtkDataRepresentation *rep) override |
| Overridden to assign IDs to each representation. More... | |
| void | RemoveRepresentationInternal (vtkDataRepresentation *rep) override |
| int | CallProcessViewRequest (vtkInformationRequestKey *passType, vtkInformation *request, vtkInformationVector *reply) |
| Subclasses can use this method to trigger a pass on all representations. More... | |
Protected Member Functions inherited from vtkView | |
| vtkView () | |
| ~vtkView () | |
| virtual vtkDataRepresentation * | CreateDefaultRepresentation (vtkAlgorithmOutput *conn) |
| virtual void | AddRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep)) |
| virtual void | RemoveRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep)) |
| virtual void | SetReuseSingleRepresentation (bool) |
| virtual bool | GetReuseSingleRepresentation () |
| virtual void | ReuseSingleRepresentationOn () |
| virtual void | ReuseSingleRepresentationOff () |
Static Protected Member Functions inherited from vtkPVView | |
| static vtkPVDataDeliveryManager * | GetDeliveryManager (vtkInformation *info) |
Protected Attributes inherited from vtkPVView | |
| double | ViewTime |
| double | CacheKey |
| bool | UseCache |
| int | Size [2] |
| int | Position [2] |
| int | PPI |
| vtkTimeStamp | UpdateTimeStamp |
| Keeps track of the time when vtkPVRenderView::Update() was called. More... | |
| vtkInformation * | RequestInformation |
| These are passed as arguments to vtkDataRepresentation::ProcessViewRequest(). More... | |
| vtkInformationVector * | ReplyInformationVector |
Protected Attributes inherited from vtkView | |
| bool | ReuseSingleRepresentation |
Definition at line 41 of file vtkPVContextView.h.
Definition at line 44 of file vtkPVContextView.h.
These methods should not be called directly. They are made public only so that the client-server-stream-interpreter can invoke them. Use the corresponding properties to change these values.
Reimplemented from vtkPVView.
Reimplemented in vtkPVXYChartView, and vtkPVPlotMatrixView.
Reimplemented from vtkView.
Based on the settings on the view, this may result in a low-resolution rendering or a simplified geometry rendering.
Implements vtkPVView.
pure virtual |
Implemented in vtkPVXYChartView, and vtkPVPlotMatrixView.
Set the interactor.
Client applications must set the interactor to enable interactivity. Note this method will also change the interactor styles set on the interactor.
| vtkRenderWindowInteractor* vtkPVContextView::GetInteractor | ( | ) |
Set the interactor.
pure virtual |
Subclasses override this method to pass on the selection to the chart using annotation link. Note this is meant to pass selection for the local process alone. The view does not manage data movement for the selection.
| vtkSelection* vtkPVContextView::GetSelection | ( | ) |
This will call this->MapSelectionToInput() to transform the selection every time a new selection is available. Subclasses should override MapSelectionToInput() to convert the selection, as appropriate.
Called vtkChartRepresentation::Export() on all visible representations. This is expected to called only on the client side after a render/update. Thus all data is expected to available on the local process.
Get/Set the title.
Get/Set the title.
pure virtual |
Implemented in vtkPVPlotMatrixView, and vtkPVXYChartView.
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
protectedvirtual |
protectedvirtual |
This is only called on the client-side. Subclasses should transform the selection in place as needed. Default implementation simply goes to the first visible representation and asks it to transform (by calling vtkChartRepresentation::MapSelectionToInput()). We need to extend the infrastructrue to work properly when making selections in views showing multiple representations, but until that happens, this naive approach works for most cases. Return false on failure.
protectedvirtual |
Definition at line 186 of file vtkPVContextView.h.
