| void | AddCompositeDataSetIndex (unsigned int index) |
| | In case of Composite datasets, set the flat index of the subtree to pass. More...
| void | RemoveAllCompositeDataSetIndices () |
| virtual void | SetGenerateCellConnectivity (bool) |
| | Allow user to enable/disable cell connectivity generation in the datamodel. More...
| virtual bool | GetGenerateCellConnectivity () |
| virtual void | SetFieldAssociation (int) |
| | Select the attribute type. More...
| virtual int | GetFieldAssociation () |
| virtual void | SetFlattenTable (int) |
| | Flatten the table, i.e. More...
| virtual int | GetFlattenTable () |
| virtual void | SetSplitComponentsNamingMode (int) |
| | Corresponds to vtkSplitColumnComponents::NamingMode. More...
| virtual int | GetSplitComponentsNamingMode () |
| virtual void | SetGenerateOriginalIds (bool) |
| | When set (default) the vtkOriginalIndices array will be added to the output. More...
| virtual bool | GetGenerateOriginalIds () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkBlockDeliveryPreprocessor () |
| | ~vtkBlockDeliveryPreprocessor () override |
| int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | This is called by the superclass. More...
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
prepares data for certain table-based representations
Despite its name, vtkBlockDeliveryPreprocessor is simply a filter that prepares an input data for certain representations that work with tables alone e.g. vtkSpreadSheetView, vtkChartRepresentation. Using vtkAttributeDataToTableFilter this convert any input data to a vtkTable (or composite of vtkTables). If FlattenTable, it uses vtkSplitColumnComponents to split multicomponent arrays into single component arrays with special names.
When dealing with composite datasets, it uses vtkExtractBlock to pass only the selected blocks.
Definition at line 38 of file vtkBlockDeliveryPreprocessor.h.
