| | This needs to be called on all instances of vtkChartSelectionRepresentation when the input is modified. More...
| void | SetVisibility (bool visible) override |
| | Set visibility of the representation. More...
| void | SetChartRepresentation (vtkChartRepresentation *repr) |
| | Get/Set the chart representation for which this is a selection representation. More...
| int | ProcessViewRequest (vtkInformationRequestKey *request, vtkInformation *ininfo, vtkInformation *outinfo) override |
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkChartSelectionRepresentation () |
| | ~vtkChartSelectionRepresentation () override |
| int | RequestData (vtkInformation *, vtkInformationVector **inputVector, vtkInformationVector *) override |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
