| std::string | GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) override |
| | Overridden to format the series name to remove the operation applied e.g. More...
| virtual void | SetQuartileVisibility (bool) |
| | When set to true, q1/q3 region is rendered. More...
| virtual bool | GetQuartileVisibility () |
| virtual void | SetRangeVisibility (bool) |
| | When set to true, min/max region is rendered. More...
| virtual bool | GetRangeVisibility () |
| virtual void | SetAverageVisibility (bool) |
| | When set to true, the avg curve is rendered. More...
| virtual bool | GetAverageVisibility () |
| virtual void | SetMedianVisibility (bool) |
| | When set to true, the med curve is rendered. More...
| virtual bool | GetMedianVisibility () |
| virtual void | SetMinVisibility (bool) |
| | When set to true, the min curve is rendered. More...
| virtual bool | GetMinVisibility () |
| virtual void | SetMaxVisibility (bool) |
| | When set to true, the max curve is rendered. More...
| virtual bool | GetMaxVisibility () |
| void | SetVisibility (bool visible) override |
| | Set visibility of the representation. More...
| void | SetChartTypeToLine () |
| void | SetChartTypeToPoints () |
| void | SetChartTypeToBar () |
| void | SetChartTypeToStacked () |
| void | SetChartTypeToBag () |
| void | SetChartTypeToFunctionalBag () |
| void | SetChartTypeToArea () |
| vtkChartXY * | GetChart () |
| | Returns the vtkChartXY instance from the view to which this representation is added. More...
| void | ClearSeriesVisibilities () |
| void | ClearLineThicknesses () |
| void | ClearLineStyles () |
| void | ClearColors () |
| void | ClearAxisCorners () |
| void | ClearMarkerSizes () |
| void | ClearMarkerStyles () |
| void | ClearLabels () |
| virtual void | SetSelectionColor (double, double, double) |
| virtual void | SetSelectionColor (double [3]) |
| virtual double * | GetSelectionColor () |
| virtual void | GetSelectionColor (double &, double &, double &) |
| virtual void | GetSelectionColor (double [3]) |
| bool | Export (vtkCSVExporter *exporter) override |
| | Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
| virtual void | SetChartType (int) |
| | Get/Set the chart type, defaults to line chart. More...
| virtual int | GetChartType () |
| virtual void | SetXAxisSeriesName (const char *) |
| | Set the series to use as the X-axis. More...
| virtual char * | GetXAxisSeriesName () |
| virtual void | SetUseIndexForXAxis (bool) |
| | Set whether the index should be used for the x axis. More...
| virtual bool | GetUseIndexForXAxis () |
| void | SetSortDataByXAxis (bool val) |
| | Get/set whether the points in the chart should be sorted by their x-axis value. More...
| virtual bool | GetSortDataByXAxis () |
| void | SetSeriesVisibility (const char *seriesname, bool visible) |
| | Set/Clear the properties for Y series/columns. More...
| void | SetLineThickness (const char *name, double value) |
| void | SetLineStyle (const char *name, int value) |
| void | SetColor (const char *name, double r, double g, double b) |
| void | SetAxisCorner (const char *name, int corner) |
| void | SetMarkerStyle (const char *name, int style) |
| void | SetMarkerSize (const char *name, double value) |
| void | SetLabel (const char *name, const char *label) |
| void | SetUseColorMapping (const char *name, bool useColorMapping) |
| void | SetLookupTable (const char *name, vtkScalarsToColors *lut) |
| const char * | GetLabel (const char *name) const |
| virtual void | SetSeriesLabelPrefix (const char *) |
| | Get/Set the series label prefix. More...
| virtual char * | GetSeriesLabelPrefix () |
| void | SetSelectionRepresentation (vtkChartSelectionRepresentation *) |
| | These must only be set during initialization before adding the representation to any views or calling Update(). More...
| | This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
| void | SetCompositeDataSetIndex (unsigned int) |
| void | AddCompositeDataSetIndex (unsigned int) |
| void | ResetCompositeDataSetIndices () |
| unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
| | Override because of internal selection representations that need to be initialized as well. More...
| virtual bool | MapSelectionToInput (vtkSelection *sel) |
| | This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
| virtual bool | MapSelectionToView (vtkSelection *sel) |
| | This is the inverse of MapSelectionToInput(). More...
| virtual bool | Export (vtkCSVExporter *vtkNotUsed(exporter)) |
| void | SetFieldAssociation (int) |
| | Set the field association for arrays to use. More...
| virtual int | GetFieldAssociation () |
| virtual void | SetFlattenTable (int) |
| | Flatten the table, i.e. More...
| virtual int | GetFlattenTable () |
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkQuartileChartRepresentation () |
| | ~vtkQuartileChartRepresentation () override |
| void | PrepareForRendering () override |
| | This method is called before actual render if this->MTime was modified since the last time this method was called. More...
| | vtkXYChartRepresentation () |
| | ~vtkXYChartRepresentation () override |
| | Overridden to remove all plots from the view. More...
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| | Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| vtkSmartPointer< vtkDataObject > | TransformTable (vtkSmartPointer< vtkDataObject >) override |
| | Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
| | vtkChartRepresentation () |
| | ~vtkChartRepresentation () override |
| vtkTable * | GetLocalOutput (bool pre_delivery=false) |
| | Convenience method to get the first vtkTable from LocalOutput, if any. More...
| virtual vtkSmartPointer< vtkDataObject > | TransformInputData (vtkDataObject *data) |
| | Method to be overridden to transform input data. More...
| virtual vtkSmartPointer< vtkDataObject > | ReduceDataToRoot (vtkDataObject *data) |
| | Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
| bool | GetLocalOutput (MapOfTables &tables) |
| | Convenience method to get all vtkTable instances with their associated names. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
