This is a custom widget for YoungsMaterialInterface filter. More...
#include <pqYoungsMaterialPropertyWidget.h>
Signals | |
| void | orderingArraysChanged () |
| Emitted when the ordering arrays change, linked ot the SMProperty. More... | |
| void | normalArraysChanged () |
| Emitted when the normal arrays change, linked ot the SMProperty. More... | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqYoungsMaterialPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parent=0) | |
| ~pqYoungsMaterialPropertyWidget () override | |
| void | setOrderingArrays (const QList< QVariant > &) |
| Get/Set the ordering arrays, linked to the SMProperty. More... | |
| QList< QVariant > | orderingArrays () const |
| void | setNormalArrays (const QList< QVariant > &) |
| Get/Set the normal arrays, linked to the SMProperty. More... | |
| QList< QVariant > | normalArrays () const |
Public Member Functions inherited from pqStringVectorPropertyWidget | |
| pqStringVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr) | |
| virtual | ~pqStringVectorPropertyWidget () |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| pqView * | view () const |
| bool | showLabel () const |
Protected Slots | |
| void | onOrderingArraysChanged () |
| Called when the ordering array is changed. More... | |
| void | onNormalArraysChanged () |
| Called when the normal array is changed. More... | |
| void | updateComboBoxes () |
| Called to initialize/update the combobox according to the current item. More... | |
| QStandardItem * | currentItem () |
| Recover the currently selecticted item in the VolumeFractionArrays widget. More... | |
Properties | |
| QList< QVariant > | orderingArrays |
| QList< QVariant > | normalArrays |
Static Public Member Functions inherited from pqStringVectorPropertyWidget | |
| static pqPropertyWidget * | createWidget (vtkSMStringVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr) |
| Factory method to instantiate a hard-coded type of pqPropertyWidget subclass for t he vtkSMStringVectorProperty. More... | |
| template<class T > | |
We use a custom widget since this filter has unusual requirements when it comes to setting OrderingArrays and NormalArrays properties.
Definition at line 48 of file pqYoungsMaterialPropertyWidget.h.
| pqYoungsMaterialPropertyWidget::pqYoungsMaterialPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | group, | ||
| QWidget * | parent = 0 |
| void pqYoungsMaterialPropertyWidget::setOrderingArrays | ( | const QList< QVariant > & | ) |
| QList<QVariant> pqYoungsMaterialPropertyWidget::orderingArrays | ( | ) | const |
| void pqYoungsMaterialPropertyWidget::setNormalArrays | ( | const QList< QVariant > & | ) |
| QList<QVariant> pqYoungsMaterialPropertyWidget::normalArrays | ( | ) | const |
signal |
signal |
protectedslot |
protectedslot |
protectedslot |
readwrite |
Definition at line 54 of file pqYoungsMaterialPropertyWidget.h.
readwrite |
