A property widget for editing a transfer function. More...
#include <pqTransferFunctionWidgetPropertyWidget.h>
Signals | |
| void | domainChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqTransferFunctionWidgetPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=0) | |
| ~pqTransferFunctionWidgetPropertyWidget () override | |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| pqView * | view () const |
| bool | showLabel () const |
Public Attributes | |
| friend | pqTransferFunctionWidgetPropertyDialog |
Protected Slots | |
| void | editButtonClicked () |
| void | propagateProxyPointsProperty () |
| void | resetRangeToDomainDefault () |
| void | updateRange () |
| Update widget with transfer function proxy value. More... | |
| void | onRangeEdited () |
| Update transfer function proxy from widgets. More... | |
| void | UpdateProperty () |
| template<class T > | |
To use this widget for a property add the 'panel_widget="transfer_function_editor"' to the property's XML.
Definition at line 49 of file pqTransferFunctionWidgetPropertyWidget.h.
explicit |
signal |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
| friend pqTransferFunctionWidgetPropertyWidget::pqTransferFunctionWidgetPropertyDialog |
Definition at line 59 of file pqTransferFunctionWidgetPropertyWidget.h.
