Property widget for selecting the ShaderReplacements to apply to a geometry. More...
#include <pqShaderReplacementsSelectorPropertyWidget.h>
| pqShaderReplacementsSelectorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqShaderReplacementsSelectorPropertyWidget () override | |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| pqView * | view () const |
| bool | showLabel () const |
Protected Slots | |
| void | updateShaderReplacements () |
| void | textChangedAndEditingFinished () |
| void | onLoad () |
| void | onDelete () |
| void | onPresetChanged (int index) |
| bool | loadShaderReplacements (const QString &filename) |
| void | refreshView () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
To use this widget for a property add 'panel_widget="shader_replacements_selector"' to the property's XML.
Definition at line 47 of file pqShaderReplacementsSelectorPropertyWidget.h.
| pqShaderReplacementsSelectorPropertyWidget::pqShaderReplacementsSelectorPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
