Property widget that can be used to edit a proxy set as the value of a ProxyProperty in a pop-up dialog.
| template<class T > |
e.g. RenderView proxy has a "GridActor3D" ProxyProperty which is set to a "GridActor3D" proxy. Using this widget allows the users to edit the properties on this GridActor3D, when present.
To use this widget, add 'panel_widget="proxy_editor"' to the property's XML.
Since it's common to have a property on the proxy being edited in the popup dialog which controls its visibility (or enabled state), we add support for putting that property as a checkbox in this pqProxyEditorPropertyWidget itself. For that, one can use ProxyEditorPropertyWidget hints.
Example XML:
<ProxyProperty name="AxesGrid" ... >
<ProxyListDomain name="proxy_list">
<Proxy group="annotations" name="GridAxes3DActor" />
</ProxyListDomain>
<Hints>
<ProxyEditorPropertyWidget property="Visibility" />
</Hints>
</ProxyProperty>
Definition at line 68 of file pqProxyEditorPropertyWidget.h.
