This behavior manages showing up of a context menu with sensible pipeline related actions for changing color/visibility etc.
#include <pqPipelineContextMenuBehavior.h>
Inherits QObject.
when the user right-clicks on top of an object in the 3D view. Currently, it only supports views with proxies that vtkSMRenderViewProxy subclasses.
Definition at line 56 of file pqPipelineContextMenuBehavior.h.
◆ pqPipelineContextMenuBehavior()
| pqPipelineContextMenuBehavior::pqPipelineContextMenuBehavior |
QObject * |
parent = 0 | ) |
◆ ~pqPipelineContextMenuBehavior()
| pqPipelineContextMenuBehavior::~pqPipelineContextMenuBehavior |
◆ onViewAdded
| void pqPipelineContextMenuBehavior::onViewAdded |
pqView * |
protectedslot |
Called when a new view is added.
We add actions to the widget for context menu if the view is a render-view.
◆ hide
| void pqPipelineContextMenuBehavior::hide |
protectedslot |
called to hide the representation.
◆ hideBlock
| void pqPipelineContextMenuBehavior::hideBlock |
protectedslot |
called to hide the block.
the action which emits the signal will contain the block index in its data().
◆ showOnlyBlock
| void pqPipelineContextMenuBehavior::showOnlyBlock |
protectedslot |
called to show only the selected block.
◆ showAllBlocks
| void pqPipelineContextMenuBehavior::showAllBlocks |
protectedslot |
called to show all blocks.
◆ unsetBlockVisibility
| void pqPipelineContextMenuBehavior::unsetBlockVisibility |
protectedslot |
called to unset the visibility flag for the block.
after this call the block will inherit the visibility from its parent. the action which emits the signal will contain the block index in its data()
◆ setBlockColor
| void pqPipelineContextMenuBehavior::setBlockColor |
protectedslot |
called to set the color for the block.
◆ unsetBlockColor
| void pqPipelineContextMenuBehavior::unsetBlockColor |
protectedslot |
called to unset the color for the block.
◆ setBlockOpacity
| void pqPipelineContextMenuBehavior::setBlockOpacity |
protectedslot |
called to set the opacity for the block.
◆ unsetBlockOpacity
| void pqPipelineContextMenuBehavior::unsetBlockOpacity |
protectedslot |
called to unset the opacity for the block.
◆ reprTypeChanged
| void pqPipelineContextMenuBehavior::reprTypeChanged |
QAction * |
action | ) |
protectedslot |
called to change the representation type.
◆ colorMenuTriggered
| void pqPipelineContextMenuBehavior::colorMenuTriggered |
QAction * |
action | ) |
protectedslot |
called to change the coloring mode.
◆ buildMenu()
called to build the context menu for the given representation.
If the picked representation was a composite data set the block index of the selected block will be passed in blockIndex.
◆ buildColorFieldsMenu()
| virtual void pqPipelineContextMenuBehavior::buildColorFieldsMenu |
pqPipelineRepresentation * |
pipelineRepr, |
QMenu * |
menu |
protectedvirtual |
called to build the color arrays submenu.
◆ eventFilter()
| bool pqPipelineContextMenuBehavior::eventFilter |
QObject * |
caller, |
QEvent * |
e |
event filter to capture the right-click.
We don't directly use mechanisms from QWidget to popup the context menu since all of those mechanism seem to eat away the right button release, leaving the render window in a dragging state.
◆ lookupBlockName()
| QString pqPipelineContextMenuBehavior::lookupBlockName |
unsigned int |
flatIndex | ) |
const |
return the name of the block from its flat index
◆ Menu
| QMenu* pqPipelineContextMenuBehavior::Menu |
◆ Position
| QPoint pqPipelineContextMenuBehavior::Position |
◆ PickedRepresentation
◆ PickedBlocks
| QList<unsigned int> pqPipelineContextMenuBehavior::PickedBlocks |
