Behaviors are classes that manage certain behaviors in the application. More...
| class | pqAlwaysConnectedBehavior |
| pqAlwaysConnectedBehavior ensures that the client always remains connected to a server. More... | |
| class | pqApplyBehavior |
| pqApplyBehavior collects the logic that needs to happen after the user hits "Apply" on the pqPropertiesPanel. More... | |
| class | pqAutoLoadPluginXMLBehavior |
| ParaView plugins can load gui configuration xmls eg. More... | |
| class | pqCategoryToolbarsBehavior |
| pqCategoryToolbarsBehavior is used when the application wants to enable categories from a pqProxyGroupMenuManager to show up in a toolbar. More... | |
| class | pqCollaborationBehavior |
| pqCollaborationBehavior ensures that a pqCollaborationManager get set when a new pqServer that support collaboration has been created. More... | |
| class | pqCommandLineOptionsBehavior |
| pqCommandLineOptionsBehavior processes command-line options on startup and performs relevant actions such as loading data files, connecting to server etc. More... | |
| class | pqCrashRecoveryBehavior |
| pqCrashRecoveryBehavior manages saving/loading of crash recovery state. More... | |
| class | pqCustomShortcutBehavior |
| pqCustomShortcutBehavior TODO More... | |
| class | pqDataTimeStepBehavior |
| pqDataTimeStepBehavior ensures that whenever a file is opened with more than 1 timestep, the application time >= the time for the last timestep. More... | |
| class | pqDefaultViewBehavior |
| pqDefaultViewBehavior ensures that when a new server connection is made, the default view of the user-specified type is automatically created. More... | |
| class | pqLockPanelsBehavior |
| Central location for controlling whether dock widgets are locked down or movable. More... | |
| class | pqModelTransformSupportBehavior |
| pqModelTransformSupportBehavior is designed for supporting ChangeOfBasis matrix for MantId. More... | |
| class | pqObjectPickingBehavior |
| pqObjectPickingBehavior is used to add support for picking "source" by clicking on it in a view. More... | |
| class | pqPersistentMainWindowStateBehavior |
| pqPersistentMainWindowStateBehavior saves and restores the MainWindow state on shutdown and restart. More... | |
| class | pqPipelineContextMenuBehavior |
| This behavior manages showing up of a context menu with sensible pipeline related actions for changing color/visibility etc. More... | |
| class | pqPluginActionGroupBehavior |
| pqPluginActionGroupBehavior adds support for loading menus/toolbars from plugins. More... | |
| class | pqPluginDockWidgetsBehavior |
| pqPluginDockWidgetsBehavior adds support for loading dock widgets from plugins. More... | |
| class | pqPluginDocumentationBehavior |
| pqPluginDocumentationBehavior is a helper class that ensures that documentation from plugins is registered with the QHelpEngine. More... | |
| class | pqPluginPathBehavior |
| Applications may want to support auto-loading of plugins from certain locations when a client-server connection is made. More... | |
| class | pqPluginSettingsBehavior |
| pqPluginSettingsBehavior adds support for adding application settings from plugins More... | |
| class | pqSpreadSheetVisibilityBehavior |
| Whenever spreadsheet view is created, ParaView wants to ensure that the active source is automatically displayed in that view. More... | |
| class | pqUndoRedoBehavior |
| pqUndoRedoBehavior enables application wide undo-redo. More... | |
| class | pqVerifyRequiredPluginBehavior |
| ParaView plugins can be loaded on the client or server before a connection is made. More... | |
| class | pqViewStreamingBehavior |
| pqViewStreamingBehavior is used to manage rendering of render-view when streaming is enabled. More... | |
| class | pqLiveSourceBehavior |
| pqLiveSourceBehavior adds support for "live" algorithms. More... | |
| class | pqParaViewBehaviors |
| creates all standard ParaView behaviourspqParaViewBehaviors creates all the behaviors used by ParaView. More... | |
| class | pqPluginToolBarBehavior |
| Behavior that monitors loaded plugins to handle any implementations of pqToolBarInterface. More... | |
| class | pqUsageLoggingBehavior |
| behavior to log usage on application startup. More... | |
Developers should simply instantiate behaviors if the expect that behavior in their client.
