widget to pause all live sources More...
#include <pqPauseLiveSourcePropertyWidget.h>
| pqPauseLiveSourcePropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=0) | |
| ~pqPauseLiveSourcePropertyWidget () override | |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| pqView * | view () const |
| bool | showLabel () const |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
pqPauseLiveSourcePropertyWidget can be added to a property on any source that is a "live source" i.e. has the <LiveSource> XML hint. This will add a button to the UI that allows the user to pause all live sources.
Definition at line 46 of file pqPauseLiveSourcePropertyWidget.h.
| pqPauseLiveSourcePropertyWidget::pqPauseLiveSourcePropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
| QWidget * | parent = 0 |
