#include <pqOMETransferFunctionsPropertyWidget.h>
| | called to set the active view. More...
| template<class T > |
◆ pqOMETransferFunctionsPropertyWidget()
| pqOMETransferFunctionsPropertyWidget::pqOMETransferFunctionsPropertyWidget |
vtkSMProxy * |
proxy, |
vtkSMPropertyGroup * |
smgroup, |
QWidget * |
parent = 0 |
◆ ~pqOMETransferFunctionsPropertyWidget()
| pqOMETransferFunctionsPropertyWidget::~pqOMETransferFunctionsPropertyWidget |
◆ event()
| bool pqOMETransferFunctionsPropertyWidget::event |
QEvent * |
evt | ) |
◆ xrgbPointsChanged
| void pqOMETransferFunctionsPropertyWidget::xrgbPointsChanged |
signal |
◆ xvmsPointsChanged
| void pqOMETransferFunctionsPropertyWidget::xvmsPointsChanged |
signal |
