| template<class T > |
pqIntMaskPropertyWidget is designed to be used for an IntVectorProperty that can have a value that is set by or-ing together flags.
The user is presented with a button with menu from which they can select multiple items. The resulting property value is determined by or-ing together the flag values for each of the checked item.
The flag/mask labels and their values are specified as hints on the XML property. The following XML snippet demonstrates how to use this property widget.
<IntVectorProperty
name=
"FacesToRender" command="SetFaceMask"
number_of_elements="1"
default_values="63"
panel_widget="int_mask">
<IntRangeDomain name="range" min="0" />
<Hints>
<Mask>
<Item name=
"Min-YZ" value=
"1" />
<Item name=
"Min-ZX" value=
"2" />
<Item name=
"Min-XY" value=
"4" />
<Item name=
"Max-YZ" value=
"8" />
<Item name=
"Max-ZX" value=
"16" />
<Item name=
"Max-XY" value=
"32" />
</Mask>
</Hints>
</IntVectorProperty>
Definition at line 69 of file pqIntMaskPropertyWidget.h.
