Property widget that can be used to set an existing pipeline connection as a proxy property. More...
#include <pqInputSelectorWidget.h>
Public Slots | |
| void | setSelectedInput (pqSMProxy) |
Signals | |
| void | selectedInputChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqInputSelectorWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=0) | |
| ~pqInputSelectorWidget () override | |
| pqSMProxy | selectedInput () const |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| pqView * | view () const |
| bool | showLabel () const |
Properties | |
| pqSMProxy | selectedInput |
| template<class T > | |
Definition at line 45 of file pqInputSelectorWidget.h.
| pqInputSelectorWidget::pqInputSelectorWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
| QWidget * | parent = 0 |
| pqSMProxy pqInputSelectorWidget::selectedInput | ( | ) | const |
slot |
signal |
readwrite |
Definition at line 49 of file pqInputSelectorWidget.h.
