pqFileNamePropertyWidget is used for the "File Name" property on the Environment annotation filter.
#include <pqFileNamePropertyWidget.h>
| | called to set the active view. More...
| template<class T > |
It customizes the resetButtonClicked() logic since the Environment filter's filename setup is custom.
Definition at line 43 of file pqFileNamePropertyWidget.h.
◆ pqFileNamePropertyWidget()
| pqFileNamePropertyWidget::pqFileNamePropertyWidget |
vtkSMProxy * |
proxy, |
vtkSMProperty * |
property, |
QWidget * |
parent = 0 |
◆ ~pqFileNamePropertyWidget()
| pqFileNamePropertyWidget::~pqFileNamePropertyWidget |
◆ clearHighlight
| void pqFileNamePropertyWidget::clearHighlight |
signal |
◆ highlightResetButton
| void pqFileNamePropertyWidget::highlightResetButton |
signal |
◆ resetButtonClicked
| virtual void pqFileNamePropertyWidget::resetButtonClicked |
protectedvirtualslot |
update the property's value using the domain.
